steering is bad!!!
Addo
roly said:
oe part number is 6K2422061DX £355.03 + VAT
worth noting it's the same as MK2 models with sports runnig gear, ie cupra, so also another route to look down
oem parts have just told me that part number is coming up as an exchange, so the dealer will need your old rack in part ex or charge you a surcharge. so he couldn't get me a price.
Black TDI Turbo
Shussssh Its A Diesel ...
Oct 2, 2005
1,175
North East
Hi ive removed the steering rack from my ibiza before really easy to do, well if you have it on a 2 poster ramp that is and a compressor.
Remove the lower steering column cowling at the bottom of the steering column inside the car and remove the two 10mm bolts and the support bracket and pull the column upwards to remove the column from the rack.
remove bothe front wheels.
remove track rod end nuts from the hub
dont have to remove the full engine bed just lower it,but will be difficult if you dont hav a hydraulic jack to lift it back in n line it.
remove the rear bed bolts and just loosen the front one, one on either side and the bed should swing downwards at the back. Theres a think 2 bolts holding the rack to the bed (bolt up and thru then a nut)
the rack should be pretty free now, might be a couple of clips holdin the pipes to the rack tht need to come off and then undo the two unions where the pipes go in.
Thats a quick guide on how to do if sorry if ive missed anything was a while ago when i did mine, however on a ramp is much easier and with a compressor as the bed bolts can be very tight also after ull need to do the tracking aswell which i did by lazer at work so was easy. but i cud imagine tht the labour costs would be quite high. Took me bout 1 - 1/2 to do mine. then tracking.
hope this is any help but would advise taking to a garage to get done tho.
Black TDI Turbo
Oct 2, 2005
1,175
North East
i got a steering rack from a trade type place partco, advanced, andrew pages motor factors cost bout £140 inc vat with trade discount
Deejay
no prawn sarnies ere
Nov 8, 2002
1,108
ЯEPUБLIC OF MANCUNIA
Thanks, you never said why you replaced though? was yours handling as bad as described in this thread and did replacing indeed 100% cure it?
ps-bump for Addo again
