STD Cupra R Suspension
evokid
87
As title, fitted std second hand low miles Cupra R suspension to my LC today..And the lower S3 strut brace...Can ye just confirm what was std fit on cupra R ?
1/ Shocks i fitted were Sachs 82 4903 557 981 (fronts) only asking to verify they were R ones....
2/ They have i assume drop link connection hole on base of spring cup (Fronts), but as LC didnt connect this.......Is it just a drop link to std anti roll bar or would i need to change roll bar too?
Many thanks.....Much better car now though as had leaky shock on pax side!!!:lol:
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
Not too sure about the part number of the shock but to fit the ARB to the shocks you'll have to have the LCR ARB, the LC one won't work with these
Aug 7, 2009
1,395
Manchester U.K
Id upgrade the arb at the same time to benifit, wouldent bother with 2nd hand, just get 2 X droplinks and an arb from DPM, Also while its try some poly bushes.
evokid
87
Thanks for replies...At moment the std cupra arb goes to lower track arm via crappy plastic mounts....So will have to upgrade to LCR ones!
Whats difference between having ARB connected to shocks as opposed to track arm?
Thanks in advance..
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
With the ARB connected to the shocks it is more effective and acting on the shocks directly instead of indirectly on the shocks through the wish bones/ hub, hub carrier then the shocks on the LC system.
As above, you cannot just connect the LCR drop links onto your existing ARB, you will have to change this to the LCR type one. This involves dropping the front sub frame
evokid
87
Thats good info cheers guys....I think if gonna drop subframe to fit ARB's then i'd wanna do the bushes/TT hub upgrade/Dogbone mount bushes etc etc......Oh damm better get saving!!!! Thanks again though ...:D
