Starting Problems
Boo
The original wee beastie
Nov 12, 2006
1,868
Eastbourne
Admittedly Steve did suggest it 1st, I just looked it up in the Haynes manual to see what it was. I will have a look in the manual about your injectors. Should be pretty easy to do.
Ben_Dunning
is the car running ok since you fitted the new sensor? was it a big job to change and also how much did it cost to replace?
cheers ben
kpanic
cheers ben
The car is now runing great, i changed the sensor that took about 5 mins! you have to be quick though as thecoolant fluid will pour out.
*NOTE* - I have changed the fuel injector and the car runns perfect! thanks for everyones help! I will now be advertising the car soon for about 900 quid with a full list of specificaitons its quite heavily modified :)
