standard cupra internals ? and what boost ?
tarzan
cupra owner from norway
Mar 15, 2008
1,122
drammen norway
do u think maybe then that my map is standard then the bypass is makin it boost to 12 ish etc ?
had a crap map on my ibiza peak on 0,9bar when i checked the turbo i found out that the dude that had chipped it had adjusted on my wastegate:blink:adjusted it back to where it should be and then got 0,6bar:censored: he had all so made a mark on my fpr and heard from a other tuner that this what someones do make some more fueling.
it`s just a minor tweak to ground pressure.so i got me a ecu with revo stage 2 and mega happy:D
m0sch
JabbaSport K04 Cupra
Feb 11, 2010
214
Windsor
www.facebook.com
well my tuner knows his vags and said mine seems to be making good power but should easily make atleast 240 + with a decent remap and when iv changed the air flow metre as its got like a part if it missing lol
jamiebennett81
what sort of boost should i be running max on the k04 with what i know standard fuel pump etc ?
The person who is mapping this should know, by keeping an eye on things like EGT's, as this leads to cracked turbo housings etc
KKK turbos get very hot as they are only small units, so any tuner worth the money should map it appropriately
depends what sort of the map the tuner puts on, steady or aggressive. Progressive I would say around 21psi peak which should hold well, or if aggressive, then a little more PSI, but expect it to tail off quicker due to the KKK turbo only being able to flow so much
m0sch
Feb 11, 2010
214
Windsor
www.facebook.com
ok well id be happy with about 240 to be honest not sure how juch hes gona run to get that should i change to a jatex filter maybe before hand or will the pipercross be ok ? like iv said before iv jus not ben a fan of pipercross but i guess its doing the job else woudlnt be on there
jamiebennett81
is that the foam type filter? never been a fan of them (not through results of logging the air flow), but I have just always preferred the jetex or green cotton air filters
both will do the job nicely
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
jetex one £38+vat for 70mm std maf - on backorder tho till next week most likely
Avoid oiled foam filters like the plague - oil will come out and contaminate the maf
alexsteele
il vouch for k04 and standard internals throwing rods... in the process of rebuilding mine with forged rods thanks to badger5... will be getting mine remapped more progressively as soon as its built! lol
alexsteele
i hadnt long owned the car unfortunately so i couldnt tell you exact figures im afraid... but it was very aggressive coming on boost..
