standard airbox part 2
paul26982
right smoothed my standard air box today took the ridges out, in pic 1, after alot of work doing that put everything back together put left the black plastick little pipe off what i think is the standard air in take to fit my 3inch pipe im putting on tomorow, as in pic 3, is this right, to put the new one were that plastic pipe was, going into the bottom of the box
also left my engine cover off, looks better and the amount of pdding was uneal
paul26982
any1, just need to know were the intake pipe goes, if its the hole at the bottle of the box
Feel
Veedubya 'velle
Jun 12, 2003
4,918
Midlands
Yes, it fits in the hole in the bottom of the box.
You should be able to squash a 3" pipe into the hole, but if you pull/cut the rubber seal from around the hole it'll fit much easier.
paul26982
thanx lads, dont know were to locate the other end, not taking a fog light out, but when attatching to the box how do you seal it so it looses no air thanx
schnipps
237
Is a green panel worth putting in paul, i still have my standard one in. Also hardly anywhere sells them, where did you get it from. Is it the best one out of the bunch?
paul26982
i think so, not as oil'y, got mine from bill at badger5, top service couldnt beat his price either £42 delivered, jabba wanted £54 delivered and awsome tried to sell me the pipercross one wich i heard bad things
tomora hopfully get the 3inch feed take the battery off and fit it, then will be sorted
