Spark Plugs
Guinness
Finally got the BMW
Nov 29, 2006
4,422
Newcastle
Can anyone tell me what I need to change mine in the 1.2. Iv got a fair idea as it seems pretty easy, just wondering what spark plugs would be best, fancy some denso iridium ones, not sure what my spark plug number is also do I need to space the gap or will they be ok?
Deleted member 19188
There are plenty of sites that will tell you what size fits a particular car, at least I think the NGK one does (which I use in my petrol car with no problems at all). Gaps will mostly be 'about' correct when supplied.
DFMM
Denso Sparks For Ibiza 12v
Just got my son a set of pre-gapped DENSO IK16, set at 1.1 mm, Iridium-tipped :--- 0.4 mm dia. Should last 60,000 miles +, like platinum ones.
ROADRUNNER AUTOPARTS LTD, £28.04 inc VaT & 1st class post.
www.carsparkplugs.com
I expect the CAT. to be kept clean due to rapid clean-running of the plugs. Long hot runs on the motorway may even clean off old soot, then the CAT> may last its full projected life of 100,000 miles
That firm also offered NGK and other qualities.
