spainels vag com logs
gazjones
dan asked me to look at them but with his being a tdi and mine a petrol its alot different to mine, was just wanting peoples input as to how things look and if possible what things are! cheers gaz!
Code:
Group A:	'002
         Engine speed	Throttle pos	Operating Cond/AC	Coolant Temp
TIME	rpm	speed/throttle/AC	80-110°C
STAMP	 /min	%		°C
0	1533	30.2	 0  0  0	87.3
1.23	1680	71.8	 0  0  0	87.3
2.43	1953	72.2	 0  0  0	87.3
3.7	2289	82.4	 0  0  0	87.3
4.91	2667	85.9	 0  0  0	87.3
6.11	3003	90.6	 0  0  0	88.2
7.31	3318	91.4	 0  0  0	88.2
8.51	3591	96.9	 0  0  0	88.2
9.73	3843	100	 0  0  0	88.2
10.97	4095	100	 0  0  0	88.2
12.17	4284	100	 0  0  0	88.2
13.37	4473	100	 0  0  0	89.1
14.57	4620	100	 0  0  0	89.1
15.77	4599	0	 0  1  0	89.1
16.97	3990	0	 0  1  0	89.1
18.17	3339	0	 0  1  0	89.1
Group B:	'004
TIME	rpm		°Ck.	-3..+3°Ck.
STAMP	 /min	 °ATDC	 CF	 CF
0.42	1575	11.2	14.3	-1.1
1.63	1764	11.5	20.4	-0.6
2.86	2058	12.4	22.4	-0.6
4.11	2457	14	25	0
5.31	2793	15.5	27	-0.6
6.51	3108	17.4	28.1	-1.7
7.71	3402	18.9	29.1	0.6
8.91	3675	20.5	30.1	1.7
10.14	3927	22	30.6	1.1
11.37	4158	23.3	30.6	0
12.57	4347	23.9	30.6	0
13.77	4515	24.5	31.1	0
14.97	4662	25.1	31.1	-0.6
16.17	4410	14	-3.1	-1.7
17.38	3780	11.8	-2	-1.1
18.57	3108	9.3	-1	-1.7
Group C:	'020
	RPM	Torque	Inj. Quantity Inj. Quantity
TIME
STAMP	 /min	 Nm	 mg/R	 mg/R
0.83	1617	316	70	0
2.03	1848	368	70	0
3.28	2163	410	70	0
4.51	2541	410	70	0
5.71	2898	410	70	0
6.91	3213	410	70	0
8.11	3486	408	70	0
9.31	3759	404	70	0
10.56	4011	396	70	0
11.77	4221	390	70	0
12.97	4410	380	70	0
14.17	4578	368	70	0
15.37	4620	110	70	0
16.57	4200	0	70	0
17.77	3570	0	70	0
19.03	2877	0	70	0
redcupratdi
Offical SCN Pole Dancer
Oct 13, 2005
755
cambridge
no more peak torque than me...lol
is the computer stopped at 410nm cos that waht mine shows on vag com
idf facxt i think the torque on vag com is inaccurate... holding 368nm at 4500rpm nice.
good to compare seat sport intercooler against forge one at a next meet on the tdi's
gazjones
yea it dosent go asbove 410 nm i belive but i just dont know what all the readings are as he used the same blocks i use which are 004 intake temp 115 boost 020 maf and so on
gazjones
thanx mork i was trying to do that as i managed to fluk it with my logs a while back just couldnt remember this time cheers!
STOCKY
Audi TT 225
Oct 6, 2004
1,005
N.Ireland
Not 100% sure on this as I know only a little but the injectors look like they are maxed out completely?? cant be very good if they are always maxed out??
Maybe not but someone on here will know.
What do the blocks you have measured measure if that makes sense?
Petrol blocks different to diesel Im sure.
Fez boy
560
Watford
Who me :confused:
My fuel is the same as that 70 max?
gazjones
its version 311.2 same as i have! these are off dans comp but same version as mine
Triple D
will try doing some more logs soon, maybe tomorrow night. What codes (blocks) should i use? then people can read it a bit better :D as i havent a clue what any of it means :lol:
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
you know there's no point just hitting 'log' and driving about?
You need to a) know what you're wanting to log b) drive accordingly
and repeat what you're doing too - no point getting one set of results with spurious readings
Triple D
Ok well this was my first time at logging, so a. i dont know what i was supposed to be logging on a tdi, what blocks to use ect, and b. i did do several runs with the same logs twice, in 3rd gear, then in 4th.
What advice would anyone recommend for me to do logs next time? and how many times should i do the same one? etc etc
stoneyfordNI
GGG GGG GGGIGITYYY
Jan 9, 2005
2,673
Lisburn NI
of course they will be maxxed out to get 230circa BHP ,
3,7,11 is what u wanna log dan , covers boost(req.and spec.) charge temps, and MAF , 20 on a remapped car is pointless i have been told by a well known tuner ,
send them over when your done , PS on the MAP sensor block your boost will go off the scale at 3000mbar above that the sensor is blind , try 1500 revs to redline in 3rd (clutch will take a kicking tho-be careful)
