South Wales Cupras Chat
Status
Not open for further replies.
rogers
rogers
Jan 8, 2006
999
bridgend, south wales
il pop down for a definate, il be gutted for u all if there weather stays like this mind is buzzing!
just my luck to book this week off work, cant do anything i was planning,
what tyres u running for the track day phil? normal road or u going something special?
Nov 2, 2004
9,335
South Wales
Yoko parada spec 2. Very grippy in the dry buy shite in the wet. Theyre a-symmetrical so i can swap fronts when the passenger side gets a beating.
rogers
rogers
Jan 8, 2006
999
im thinkin on going for yoko 048's when my tyres are shagged, i thought as u were going down the track car oute u would have got sum track wheels with track tyres!
by the look at the photo uv got the bucket seat in the passenger side? or was that a test run?
davidol
New ghetto whip :)
Aug 17, 2004
1,978
Cardiff
need some advice on bleeding the brakes on the missus' corsa C, changed the dics and pads earlier (pads were non existant, discs were scored to f.cuk) and slackened off the bleed nipple to allow me to push the piston back, get the feeling i should of connected up some tubing to the bleed nipple though and left it submerged in some fresh brake fluid to prevent air entering the system, which i didnt, and now the brakes work fine but theres alot of travel in the pedal before they start working
can someone talk me through the bleeding process, can i bleed just the fronts? I get the feeling i need to get my mate to sit in the car and force the brake pedal all the way down whilst i slacken the bleed nipple until fresh fluid comes out then tighten it back up....that right? any order i should do them in?
rogers
rogers
Jan 8, 2006
999
u need two people to do it properly,
this is how iv done it in the past,
open the brake fluid res, under the engine bay
loosen the bleed nipple
pump the pedel travelling all the way to the floor in one motion
whilst u poor fresh fluid in the res, ( put a pot under the caliper as it will go everywhere!
you might have to do it a couple of times to get the right fluid level, but ul know when theres no air etc becuase the fluid will come out in a continuous motion not spitting
if your by your self you can buy kits called eyzy bleed kits basically a seringine with a connection so you drag the fluid out instead of having the pedel pumped
that should get u started!
davidol
New ghetto whip :)
Aug 17, 2004
1,978
Cardiff
all done guys, slackened off the nipples one at a time whilst mate held pedal down and tightened up back up, much better pedal feel now!
gavin31
Hi Anyone Know Where To Get A Full Service And Belts Done In Southwales, Thanks In Advance
Forbez
Huge Member!
Feb 11, 2004
5,878
S.Wales
Dubsport in llantrisant is the only specialist i'm aware of in the south wales area at the mo.
Right back to proper cars, and not girly school run corsa's,
8 inch wheels, will the fit the cupra, without to much problem?
The other thing, they may be 18's.
Status
