South Wales Cupras Chat
Status
Not open for further replies.
Forbez
Huge Member!
Feb 11, 2004
5,878
S.Wales
Yo, Roger's we'll sort something out for that bumper too if you've finished with it.
I may be down Peter Lloyd's soon, which is down your way isnt it?
Nov 2, 2004
9,335
South Wales
Quick pick of my handywork....
May 2, 2006
2,758
looks good phil, like the seat :thumbup:
frames look alot different to mine
can you let me know if you manage to get your airbag light off while still having the airbags in your dash/steering wheel on (anotherwords, just disabling the seat airbags and having no dash light)
May 2, 2006
2,758
il give it a bash, if it doesnt become more obvious once in the module which one is seats etc etc then il leave it and start a thread
will let you know
Nov 2, 2004
9,335
South Wales
Cool, i wouldnt worry about it tho, its just an adaption setting, 0 and 1, on and off so it might be a case of trial and error.
Thanks dave (DPJ)
6 sensors? 2 seat airbags, steering wheel, passenger side and 2 tensioners.
May 2, 2006
2,758
didnt end up doing it
i nipped out, as soon as i clicked on airbags it gave me a error that a number of cars (mine included) would set off the airbags just by going into the controller, so i thought its a better idea to do it on my drive at home later rather than being stuck in a random carpark 60miles away from were i live if they did go off :D
Nov 2, 2004
9,335
South Wales
It has been asked several times in this forum about disabling airbags because of aftermarket seats, so I'll post this here.
Check for local regulations before performing any deactivation/reactivation. For example, Germany requires that this must be checked by an authorized test center and entry made in the vehicle documents.
This information is shared for persons working on cars and need to temporarily disable the airbags, or others with a need to do so (e.g. frequently carrying a small child in the front passenger seat). The airbags are there for safety, I recommend that they normally be enabled.
Note: this description is based on using VAG-COM from Ross-Tech and having prior experience using it. If using anything else you will have to adapt the instructions.
1) determine if your car can do this. Use VAG-COM (or equivalent) to access the airbag controller. Look at the Component box in the upper right corner. In the middle of the string you should see 'VWx' where x is a number. This number must be 5 or higher. Anything lower requires a special resistance kit installation (1J0 998 521). An exception to this is VW3 with part number 1J0 909 609. This controller does not require the resistance connector.
2) Click on 10-Adaptation
3) Click up for the channel number to get to channel 01. This is the passenger front airbag channel. The value is 0 (zero) for 'enabled'. Click the up arrow to make it a '1'. Click 'Save' and confirm the prompt. This will disable that airbag.
For the other airbags, disabling them is a matter of choosing a different channel.
1 - passenger front
2 - driver front (steering wheel)
3 - passenger side (seat airbag)
4 - driver side
5 - passenger belt tensioner
6 - driver belt tensioner
7 - passenger head
8 - driver head
Enabling the airbag is just a matter of performing the same steps but decrementing the channel value from 1 to 0.
When an airbag is disabled, the airbag light will light on the cluster for the normal 4 seconds when you first turn the starter key to the on position, then additionally flash for 12 seconds.
jivejester
336
I got clouted by a bull, cant sit down properly now. Killed a delivery milage audi a6 avant driving across spain too :D
Just realised how much I utterly hate this cesspit of a country, and my car.
First time I've driven the car in 7 days, 5 miles down the road my B&M quickshift sheared at the ball joint.
Status
