South Wales Cupras Chat
Status
Not open for further replies.
Nov 2, 2004
9,335
South Wales
Phil did your Spec clutch come with all the required bolts? I've ordered one today with the lightened flywheel and just wondered if i need to order the bolts seperately?
I had to order flywheel and pressure plate bolts from Audi, i posted the part numbers in the par number thread.
I'll have that then Philly. How much you wanting for it?
I'm sure mat will answer that as its his really. If your coming to the meet on the 27th you can have it then.
davidol
New ghetto whip :)
Aug 17, 2004
1,978
Cardiff
evo trackday was fun today, 2 write offs, one 8 FQ320 and one 4 GSR, both hit the banking after a fishtail...
carbon copy of rogers motor was there, black smoothed front bumper, white compomotive MO's, looked good :)
jivejester
336
Where was that too?
Downpipe day tommorow :D
jivejester
336
ermm... big pipe little hole lol.
We did mine first as the test, it fouled on everything. The lambda bosses are almost pointing down, which is bad for sensor life. Add to that my pipe had a 3rd boss for the wideband, welded opposite the primary. This means that the wb boss is now pointing straight up, so no wb for now.
As westec ****ed up my supersprint pipe, we had to spend some time getting the pipe to fit properly. Finally got it sorted though and its solid as a rock.
Started phil's expecting it too be easy. No chance, lambdas are seized in the milltek pipe. We fitted the decat pipe without the o2's and he drove it home. Not such a big deal since it aint used daily, and the garage is litteraly 1/2mile from his place. Goto sort it this week/next weekend.
Mine sounds really nice, didnt sound any different on idle, but under load its awesome. Really pleased with the sound but narked with the fitting. Spool up is awesome too.
Status
