South Wales Cupras Chat
Status
Not open for further replies.
Dec 3, 2007
2,475
cardiff
quick question for you all. because your all so helpful and loving helping ppl. lol.
i cleaned my dv yesterday when i done my bypass. took it completely apart and cleaned using wd40. do i have to grease the piston part in it or does it stay dry. i have no idea as there was some black oil in it which i thought might have come from some where else. would this make it give out a strange noise?
Nov 2, 2004
9,334
South Wales
You need to use high temp grease on all moving parts, basically around where the o-rings are trying to make the seal.
You'll find the boost acting up if theres no grease or the wrong grease as the piston tends to stick.
Dec 3, 2007
2,475
cardiff
it tends to sound more like a rubbing noise than a nice smooth sound. Cheers phil. Will have a look at what i got in the shed.
jivejester
336
Some more goodies turned up from the badger today
Dec 3, 2007
2,475
cardiff
i have tried to grease up my dv but still sounds like its rubbing. It sounds nice with boost on low rev's but as soon as i boot the car it sound's like its stabbing bad. Is there any chance i could of ruined it when it was dry? It is on the right was as well
jivejester
336
Jivey, whats that? It looks like a large cylinder bearing from a skate board wheel.
VT wishbone bush to replace my **** powerflex bushes. Going on sunday along with the wheel studs and a few other things ;)
You still wanting those stainless bolts?
devine: what grease did you use, ideally it should be castrol red rubber grease.
Forbez
Huge Member!
Feb 11, 2004
5,877
S.Wales
Stainless bolts? Are you talking to me?
May pop on on sunday to lend a hand if you need one.
Phil, when you going skiing? Today / Tomoz?
jivejester
336
Aye stainless cap heads for the bolt down coils. I'll be at the 'rents place on sunday, welcome to pop down if ya like.
Goto strip the passenger coilover and fit the bushes so I'll be there a little while.
jivejester
336
I had problems using LM grease, so then tracked down red rubber grease. I got a 500ml tub if you want some.
If your gunno buy another, get a chinese copy from the 'bay. I've had one for 6 months and its identical to the forge 007p i sold, albeit 30 quid cheaper!
Just ordered me a black apexi avcr ebc :D :D :D
Dec 3, 2007
2,475
cardiff
i know my signature say's different but i think i got a chinese copy already as there was no stamp on it with any brand name. I was lied to! Tut tut.
Matt yours did sound nice the other day mind. Might take a little look on there now.
Status
