Status
Not open for further replies.
My latest purchases:
And cant remember whether i posted my foam gun in action:
Either end, (bright bottles) are wash and gloss, a foamy shampoo.
2nd from left is Wet Mirror finish, a gloss magnifier
and 3rd from left is Coconut scent air freshener.
Cool. Let me know how you get on with the shampoo. I need to get some soon as i'm comin to the end of my Poorboys Slick and Suds.
Got about 150 quid to spend on a 4 channel amp, any reccomendations? I know its not a massive amount of money but i'm sure something could be had for that. Want to run my front components and a sub off it. More after SQ that out and out noise.
Will do Phil, i'm still working my way through my PB Slick and Suds, but i'll give the CG stuff a go!
Stan, you fitted an ACT gauge didnt you, how difficult is the wiring of it? Thinking of fitting one in the Cupra R gauge pod, once i fit the gauges.
And in talking of the gauges, what wiring will i need to wire them up?
Matt never got his working if i remember right. I'd like to have one tho.
I fancy a scangauge coz i'll be without a laptop soon and it reads and clears codes as well as the gauge side of things.
Hmm, Not sure. I did get some kind of T piece thing with the gauges also.
You fitted both of yours into different places didnt you.
Any idea where i can get one to fit both into?
I've also got this:
Oil temperature bracket
* Provides easy installation of oil temp/pressure gauges
* supplied with 6mm & 8mm BSP fittings
* Suitable for all oil gauges
* Connect oil temp & pressure gauges together at oil pressure switch
I used a M10x1 male and 1/8NPT female adaptor for my oil pressure on the oil filter housing which you can get from Demon Tweeks.
And a sump plug with 1/8NPT female which went in the sump which i used for my oil temp gauge. Got that from Burton Power.
Status
