Snow Foam
McCann87
167
Middlesbrough
Is snow foam and the snow lance really worth it?
Apart from it covering your car in foam, does it make more of a difference than just washing it?
Sio_08
I would say so?the snow foam is more for using as a pre wash to get all the crap of your car
McCann87
167
Middlesbrough
Surely the jet washer on its own would get it off though?
I've never used a snow foam, was looking into getting one but after looking at the price and thinking whether or not would make much more difference i didnt see the point?
RickyD1975
Audi A6 2.0TDI 170 S-Line
Jan 2, 2008
572
North East
I got a snowfoam lance off my parents for Xmas and they are ideal for those winter months. Mine's the one from Auto Raechem which are always on Ebay.
Mine won't be used again until October time when the weather is poor. I prefer to use the two bucket method in the drier months.
Sio_08
Well i normally use a pressure washer at first but i want to pressure wash then snow foam then hand wash due to it gets alot of crap on the car.
Crafoo
Crazy Fool!
Apr 30, 2005
5,498
At home
I bought a lance and a bottle of snowfoam because loads of people were raving about them, I use it on a regular basis but it doesn't seem to pull as much dirt off the car as I thought it would. I normally go round the car twice with the foam, leave it to work for a few minutes then rinse off.
vroomtshh
4,222
Dreghorn, Scotland
You should snow foam before pressure washing. Pressure washing will blast the grit across the surface of the paint, causing micro marring. Whether that bothers you or not is a different matter, but snow foam lifts big particles up away from the paintwork, rather than forcing it to run across the car.
Sio_08
thats what i would be doing sorry just want to buy some decent snow foam and not stuff which is crap?
Cheers!
demon_dan
Valet Pro - PH Neutral Snow Foam is good, I use it with a squirt of Chemical Guys Maxi Suds :happy:
Sep 3, 2009
1,230
Walsall, West Mids
exactly what i use ;)
on a weekly wash i'll have the dialled round at about 50% mixture so the foam clings to the car but is pretty much gone after 5 minutes or just over. If the car hasnt been cleaned for a couple of weeks then its dialled to about 75% and the foam will cling to the car for a good 10 minutes before i rinse it off.
if you look at the ground where the foam is falling from the car you should be able to see the dirt in the foam... a bit like dirty slush after its been snowing. if you are not seeing this then the mixture isnt working long enough on the car.
essentially the whole point of using snow foam, 2 buckets and wash mitts etc is to try and imflict the least amount of damage to the paint work as you can when cleaning it. the foam is used to remove as much of the heavy soiling as possible so that the wash stage is only removing the lighter contamination.
Sio_08
I'm trying to locate some of auto rae chem cheaper than on ebay and im trying to get a sample! Another quick question do you need a separate lance for a karcher power washer?due to i have a tank to put fluid in but not sure how i go about using all of this? Sorry!
Many Thanks
Sep 3, 2009
1,230
Walsall, West Mids
Many Thanks
If you use the tank on the unit it will only pull the product through and mix it through the normal lance and not really produce the foam you are looking for or need.
You can buy a karcher foaming lance but they arent much better to be honest.
I've used a few and still ended up buying a dedicated foam lance for the Karcher
Viking
Insurance co's are crap.
May 19, 2007
2,317
Near Richmond, North Yorks
Many Thanks
I have a Karcher foam bottle in the garage you can have for a fiver. If you're close to me you can also have a sample of snow foam.
RickyD1975
Jan 2, 2008
572
North East
Simon,
Just send them a message via the ebay site and I'm sure they will confirm 100% that it will fit your machine.
RickyD
Sio_08
Hello
i have done but didn't explain it didn't know if anyone has used it before and could give me some advice?
Cheers!
