smokey lol
ibiza..fr
hi there mite just be me not used to havin a dirty diesel lol but on start up on cold puff a nice bit of blue out this normal???
dErZ
203
Surrey
I get it too, smells like some kids put their sweeties in there though ;) Oil in filler cap nice and black, not using any oil either so dont know why it happens. Only last a couple of seconds and then its gone...
ross p
Back at last....
Jul 13, 2007
467
Glasgow
www.firstrespondernm.co.uk
Blue smoke means oil.
So this means that somewere, oil is seeping through into the cylinders and sitting.
It could be as simple as worn rings which as causing this to happen.
If under warrenty get it checked out, if not take it to a garage and get it checked.
T. Spark
Yes, however it seems most in really low temps do this. So I wouldnt actually say there is deffo something wrng with a car that has "abit" of whiteish/blue smoke simple on start up. Depending on amounts, temps etc then yes get it checked out!
ross p
Back at last....
Jul 13, 2007
467
Glasgow
If its bothering you then i'd say get it checked just for peace of mind.
Not saying this is the case but one simple fault could lead to something big.
After all if its something alot of tdi owners get, then a small letter could be wrote to Seat about it.
Nath.
The Gentlemans Express
Jan 1, 2006
8,620
16
EASTLEIGH, HAMPSHIRE
Lets not forget that diesel is an oil and for a few seconds on cold start the engine does not always burn clean. This blue smoke is quite possibly just diesel that is not being burnt fully.
Maybe get your glow plugs checked, that is if you do use them :think:
st10587
i only brake for cake!!!!
Oct 4, 2007
3,669
Hindhead
ok a little update, i just poped mine in because of blue smoke on start up when cold and they say the timing was slightly out which was causing it
Nath.
Jan 1, 2006
8,620
16
Yep, timing out could cause the diesel burn to be a bit dirty, that could make a bit of blue on startup.
I remember on my very old 1983 (A REG) astra diesel you had glow plugs and also a timing advance for cold starts. If you pulled the timing advance out when the engine was warm it would make blue smoke and also make real bad tractor noises.
st10587
Oct 4, 2007
3,669
Hindhead
thanks for the info, i now feel a little bit better about it and its not just the dealer trying to fob me off. how does the timing get out of sync all by itself? just streching of the cambelt? or you think its always been out?
Nath.
Jan 1, 2006
8,620
16
I doubt that the "static" timing was out, Probably just the injection timing was adjusted. Don't know if this is done electronically or by phisically moving a sensor or something.
kriso
_______ C U P R A _______
Jan 29, 2007
2,325
Brighton
The timing is adjusted on cold starts when the secondary air pump is running. Would have also been fiddled with when you got it remapped I guess?
sooty22
sooty22
Dec 28, 2006
726
nera richmond north yorks
it happens on cold start as the engne inside has cold air which has been sat since the last startup, mine does this and i looked into it. the cold air is dense but for some funny reason been sat under pressure in the cylinders when fired it burns as white, it is nothing to worry about but daunting at first.
Nath.
Jan 1, 2006
8,620
16
^^^^I'm not getting that, sorry.
Everyone knows that blue smoke comes from burning oil, Chip pans make blue smoke just before they catch fire. My theory that diesel is an oil and doesn't combust clean/hot for a second or two makes more sense to me.
That is unless there is engine oil leeking past the valve stem seals, Ford CVH engine stylee.
