is this a bumper off job?
was told but red that the clips are crap what can i replace them with
smee
Jubilee clips should be fine, as long as used in the correct way. A lot of people fail to tighten them when they are fully over the pipe or recess.
You would be best off removing the bumper, and that allows you to check all the pipes. PLus do some runs up and down the road to check it all before you refit. As mentioned the pipes that come off the intercooler are the worst. Especially the lower one. Also check that all the connectors are ok on the top pipe that goes across the engine, the rubber seals on these can go, only a couple of pence to replace. Also on the diesels there are not too many jubilee clips used. You could always double up if you are still not trusting them. Remmber too, do not over tighten them,
