Smell of eggs and Loud ticking noise
rosscopecotrain
135
Chepstow
Was a bit naughty this morning I ragged the car went it wasn't hot enough. I could then smell like an eggy smell thru the vents and there was a loud clicking noise coming from the engine. I pulled over turned if off and back on and it seemed fine. Anyone any ideas what it could be?
Deleted member 20376
sounds like the cat if its ok now it should be ok probably cus u dint let it warm up. my exhaust clicks when i turn it off but ive had that with a lot of cars.
jezza49
cupra tdi 150
Jul 1, 2008
108
maidstone, kent
Sounds to me like the cat,should get it checked out mate the ticking noise seems to me the typical noise you get after a good ragging cooling down tapping:confused:
Jonny
slightly insane monkey
Jul 5, 2005
769
South Wales
If the smell was only there for a short time, probably nothing to be alarmed about... all of my cars have given off a puff of pong at some point.
"Why do CAT emissions sometimes smell of rotten eggs?
This can sometimes happen when trace elements of sulphur in petrol form minute quantities of hydrogen sulphide on the catalyst. This generally only occurs when there is a rapid change of engine speed and load. It is a phenomena of new units and should reduce with age."
http://www.buypartsby.co.uk/catalytic_answers.php
"Q Why Does The Exhaust Have A "Rotten Egg" Smell?
A Many times on first start-up in the morning, the exhaust may smell like "rotten eggs". This is due to rich fuel condition with a cold engine. However, as the engine warms up, this smell should go away. If it does not, converter damage could possibly follow with extended driving."
http://www.catalyticconverter.org/faq/index.htm
If the smell is appears frequently & for prolonged periods, then you have problems.
Jonny
Jul 5, 2005
769
South Wales
Forgot to ask, can you hear the ticking noise while you're on the move, or only when you're stopped & at idle?
If it's only when you're stopped & at idle, it's probably the charcoal canister... located on the drivers side, behind the washer bottle. That ticking noise is normal :)
westoncraig
reviver of old threads :)
Aug 7, 2005
826
weston-SUPER-mare
alot of the time its where the metal has heated up and expanded, then contracts.. i used to get it sometimes on my ibiza after long trips to uni, then when it stops it begins to cool down
MonkeeHanger
Sounds like someone planted an Improvised Eggsplosive Device in your engine bay. Annoyed any terrorists lately?
