Skreeching sound when breaking?
caveo
Also is there a lip round your disks,it my need grinding down, this happened and my dads 307
rick16v
normal brake squeal lor a scratching, rasping, scraping sound? I've read that Brembos often squeal quite a bit and it's no problem. Mine do. Dirty rasping cratching noise however is possibly not good.
Havok316
Boost Junky
Jun 6, 2006
1,220
Weston-super-Mare
grab a hose pipe and blast the crap out of the calipers etc and give it a whurl after (obviously when its dried a bit) It helped me but i changed my lipped disks and pads since then.
storeyd
Newcastle
Jul 5, 2006
218
Newcastle
I would recommend to take the pads out and check the condition. If ok then you should clean all the built up dirt on the running surfaces between the pad and caliper with a file and then cover with copper slip. You will be shocked with the amount of hardened crud thats in there and the average garage will never do this. Then put copper slip on the contact surface on the back of the pads. Be very careful not to get any on the pads or disc as they will be contaminated and will have to be chucked.
I do this every 6 months to my brakes, back and front. After you have done them you can feel the difference in braking sensitivity. Much improved.
I would be suprised if they are still squeeling after this.
iainhome
InstantKarma
Jan 27, 2008
49
Hamilton, Scotland
blasted them with my dads power jet, seems to have sorted the problem!
on another note, is it a straight-forward job to paint your brake calipers (red)? and wot paint would I need to get?
