Single high-pitch beep just after switching off
ettlz
141
I'd just returned from filling the tank, parked up on the driveway and switched off my 56 Ibiza. Before I'd removed the key, the dash emitted a single high-pitched "beep" lasting about a second. (This was a real beep, like a digital watch --- much higher than the usual synth "ding" you get if you leave the headlights on and open the door.) There were no warning lights on, the car is operating fine, and I'd not even opened the door. I switched the engine back on but no fault lights showed, and all the fluids are at the correct level (it was only serviced 3 weeks ago, and yes, the service counter was reset). Any ideas?
rashcupra
MV AGUSTA & 1.8T DUB MK4
Oct 15, 2006
6,517
crawley
did the temperature drop to cold?? and outside temp warning beep was emitted just before you turned the key off??
keep your lights on and open th door was it the same beep tone as that?? or is it the same beep tone as when you driving about and the handbrake is lifted up???
ettlz
141
No, temperature is quite moderate down here. (About 15C? Certainly not freezing!) Again, this was not the lights on/low-fuel "ding", it was a plain old piezo-style "beep". (It may be the same as the "oil pressure" warning sound I once heard when I stalled it manoeuvring on gravel.)
Ad Lav
vRS...
Nov 10, 2006
4,230
Kent
The cold temp sensor will 'bing' at 4.0C, well in mine anyway, lights and fuel are a no, sure it wasn't an indicator down?
pauliepaul
stop making my car dirty
Aug 19, 2007
232
cornwall
that temperature beep has caught me out quite a few times, you're driving along and it just hits you out of the blue, you just prey it isn't coupled with the engine management light ;)
ettlz
141
Well I don't know why it beeped at me like that. I've just been out for a rather, er, enthusiastic drive and I saw no warning lights, 16-18C on the temperature monitor, all subsystems working fine, power delivery normal, and this time no beep on shutdown... it's a mystery.
I'm now trying to think if there was anything else I had in the car that beeps.
CHR15B
2,567
9
Scotland
Heh, I get that shitty sounding 'bing' too.
Lights, Fuel and Indicator give off the same drone - different to the 'bing' :)
