Viking
The document shows what happens between sliding contacts as these products were designed to minimise wear on this type of component. The physics is exactly the same in a static automtive connector particularly on an engine, every failure described does happen on all automotive connectors over a period of time. The vibration causes fretting leading to corrosion, high resistance and intermittent electrical faults.
I totally agree that removing the connector, gentle solvent cleaning and addition of a dilectric grease will improve the connection and solve many of the gremlins, this is without question a very good preventative maintenace to undertake.
The issue I have is that in a number of posts the substance used is described as silicon grease. Silicon grease will cause untold issues if applied to some of the engine sensor interconnects as it has a very high resistance, even if it is only a few molecules thick. I think it is a missnaming issue but if somebody out there does put silicon grease on their engine interconnects they could have endless random DTCs.
There are products called Silicone Dielectric Grease and are described as "Super Lube® Silicone Dielectric Grease is translucent white, clean and clear in appearance and exhibits high dielectric strength and is compatible with most plastics." which are good for things like putting on torqued up earth stud connections or battery connection etc to stop moisture penetreation. The point is that they have a high dielectric strength, this is not good for low current applications such as MAF MAP etc.
Be careful, know what you are putting on before you apply it.
