Side repeaters - faulty!
MrMogensen
Hello everyone!
Side repeaters isn't working properly... :cry:
When I push the side repeater arm to flash either right or left side, I found out that the side repeater light lights up constantly to each respective side (depending on what direction I push the arm).
There is no "click" sound (from the relay I guess) to tell you that you got the side repeaters turned on, and the indicator light for side repeater (below the speedometer) is constantly on - matching the constant glowing side repeaters.
A few weeks ago the problem appeared first time, and has appeared a few times since (and now constant). I thought it was the side repeater arm itself that was making rubbish since I could just wriggle the arm up and down fast to provoke the side repeater light to function properly.
Is this simply a faulty relay? Couldn't be the side repeater arm with the new constant fault could it? :shrug:
(At least the new fuelpump is working perfectly...)
