show us your ko3s resaults
cupramillo
The "Red Baron"
Feb 24, 2008
2,039
South London
I dont think a ko3s would last long if it was running a true 240-250 with out WMI, i think they can run 225-235bhp for a safe reliable car. Anyone know what ko3hybrids are REALLY putting out? Some say 260bhp then some say its at the higher end more 280-300bhp? Guess we wont know until some one gets theirs RR'd
M87NER
MATNER
Mar 11, 2007
1,338
Stoke-on-Trent
ive had my Hybrid roaded, at first i got 276bhp and 292 ft lb,
but know need it roaded again as at awesome gti i got 265bhp and 300 ft lb (in 30 degrees temperature ! ) with it loosing boost after 5k so should see higher now with it holding boost to redline.
p34ch3y
tastefully modified
Oct 17, 2005
2,879
cambs
i have a ko3s and other stuff ready to be fitted and maped im just wondering at what revs dose the boost tail off at,on my ko3 at the mo it hits 20pst then almost strate awy it starts to tail of to around 12psi,what should i expect for the ko3s
cupramillo
The "Red Baron"
Feb 24, 2008
2,039
South London
I did the same as you peachy. To be honest, it is a good and fairly cheap upgrade to do, but i think your better off going straight to hybrid and making it one step instead of 2, if thats the road you want to go down?
As for how it feels, you can definatly feel the difference in power, ok its not MASSIVE but noticable. When i first got mine fitted and mapped, it makes a much nicer spool up sound, can really hear it whistle. It spools up just as fast as the ko3 and will hold the power until about 5.5k then you still do feel it tail off, but ive already changed gears by that point. It will still lose power like the ko3 does, so dont expect it to pull all the way to the redline
p34ch3y
tastefully modified
Oct 17, 2005
2,879
cambs
yea i dont want it to crazy as my car is my every day hack, i think for my self ko3s power as im ok with the ko3 the only thing i would change about that is to make it hold abit longer so in my eyes ko3s will be ideal for me
s1l3nc3r
ASBO car.
Jun 30, 2008
1,558
essex
my k03 holds boost quite well boost just under 1.5 bar peak about 20-21psi
but alot must depend on what map you have aswell as i have an amd map and peak power isnt untill 4.5...
p34ch3y
tastefully modified
Oct 17, 2005
2,879
cambs
so realy my first cupra did quite well then on the std ko3 216 at the fly 206 at the engine
jamiebennett81
I am getting mine RR in Sept at the AMD RR day
doing some logs tonight as I think I have finally sorted out the actuator so will show how well it holds the boost
jamiebennett81
Does it still hold boost and pull well all the way to the red line if need be Tony?
yes, boosting to 1.4 bar (less with a leon due to 19mm pins and the ibiza having 20mm pins)
holds 1.1bar to around 6900 rpm (16psi)
logs will give a more accurate tale tonight
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
I was running HB9 T9 with 5.25 added showing 5`s in block 020.
The only problem i had when fitting my high flow manni the first time round was the fact a washer manged to find its way down to the turbine, i still cant understand to this day how the hell it got down there but it did!
Im on my 2nd manifold now and that one has also cracked i belive due to the sound it makes on idle, im picking my spare up tommrow from the welders, see how long that lasts.
cupramillo
The "Red Baron"
Feb 24, 2008
2,039
South London
You got a Kenetic on Benny? Why dont you go for an INA manifold? Getting mine ordered today. Its a good time to take advantage of the weak dollar, mani is only costing 200quid delivered!!:-o:D
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
They honerd me a free one.
Apprently DPJ had his welded up and its still holding strong, only time will tell.
