a few pics from edition
cool pics kezz... just noticed aswel your spliter is same as mine, why had it got the gap at the end but the rest is covered (like it needs to be cut out :S)
The clocks should come out through the steering wheel, I had my standard steering wheel on when I changed my bulbs and got them through the steering wheel.
I have a light in my boot but its a boot light from a Gti. Works rather well. Although I am planning on building abit of a boot build.
How did you wire up the one in the centre console and footwells??
David, I've fiddled with clocks / units many times on my old Ibiza ... Basically, carefully unscrew the two screws (which I'm assuming you've already done), and slide it forward on it's resting pivots. Disconnect the connector to the rear of the unit so you've got a little more play.
Now for the tricky part, leave it on one of the pivots and get it out at an angle, sideways... it should come out. Be careful not to scuff the dash cutout too much, or tear the dash plastic / facing. Finally pull it through the steering wheel as Craig states. You'll get it out, with care, I did
i love a wide rear
ballbeater, yours isnt bad either, any plans?
yours isnt bad phill your full of complements you are kiwi is my all time fave colour
