Seat sound system subwoofer W RMS
bretth1974
561
not vcds, the menu on the infotainment screen.
Might have to venture outside and look....
Please do.... I can't find any sub on/off on mine and I am sure my sub should be louder than it is..... So chances are it may be switched off (or I am deaf).
I turn it all the way to level 9 and it doesn't seem to make much difference at all.
Sent from my SM-G900F using Tapatalk
Raven
223
11
Have you opened the boot and listened to the sub? You'll definitely notice if it's alive or not.
Sent using my fingers
andrewpain
1,852
Meppershall Beds.
you're right.turn on radio, "set up" button, "sound set up", and there's a slider for the subwoofer.
Also a set of sliders under manual setup for general sound - as I AM a bit deaf, mine are all turned to max (no subtlety here).
didn't want to go to car because every time I get in it I want to drive it.....not allowed to do that till tomorrow, doctors orders.
sorry I couldn't help you, Brett
kazand
Is powered by Medtronics
Jun 6, 2010
4,138
73
Brum
Recently had a puncture ( :censored: ) , unplugged sub to fit spare, didn't plug it back in till puncture was fixed, plugged it back in when stereo was on ( low level, I'm a thoughtful neighbour ;) ) and you can really notice a difference.
andrewpain
1,852
Meppershall Beds.
it is pluged into the lead in the boot, isn't it?
StylancePaul
CUPRA Owner
May 31, 2006
308
Cambridge, UK
I have VCDS but could not find where to do it.
I could change boot logo on screen. It is done in information elect. address 5f ling coding byte 18. But none of the options enabled seat sound logo. I appreciate if somebody can tell me place of seat sound coding.
Samsung Galaxy Note 5 Cihazimdan Gonderildi
I've just grabbed the coding for my 5F module, which has SEAT Sound installed, take a look and see if there are any differences from your own.
Coding: 04730001FF0A000021111101000800002F0202060100010046
ysfdncr
176
12
37
New Jersey, USA
Thanks for this great info. I tried but no success. It did not bring logo on boot. Maybe there is another setting. By the way, do you have navigatiın system on your car? If so I wonder gateway installation list of VCDS. When you connected and run auto scan what gateways are listed in list? Is there 37 - Navigation option ?
Thanks.
ysfdncr
176
12
37
New Jersey, USA
Bring subwoofer level to middle you will see it performs better.
StylancePaul
CUPRA Owner
May 31, 2006
308
Cambridge, UK
Thanks.
I do have navigation, its standard on the Cupra.
No module on address 37, everything is done through information electrics (5F) If i'm not mistaken module 37 was the old nav units used in the Mk 2's.
Modules look like this:
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
32-Differential Locks -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
A9-Struct. Borne Sound -- Status: OK 0000
ysfdncr
176
12
37
New Jersey, USA
I found an information saying that seat sound logo on boot can be enabled with Green Engineering Menu. So I enabled green engineering menu using VCP but there are 10s of settings and I could not find anything related with seat sound. Does anybody has any info about this?
ysfdncr
176
12
37
New Jersey, USA
Hi. Can you share adaptation map of the 5F Information Elect Ecu ? You can get this by vcds > Applications > Controller Channler Map > Controller Adddress: 5F | Adaptation and CSV file selected. It will give you a CSV file dump of adaptations.
Warm Regards.
Charliessmith
494
51
Does anyone know how to install a sub with a built in amp to the original head unit in a cupra 290 mk3 2016.
The sub is a vibe black air vented v12.
