Seat reverse camer badge
p11lkw
325
Anyone near Doncaster- Grimsby- Lincoln or nearby areas within reason that wants a good look at how I've done it all let me know.
bigbadjay
1,670
26
North Manchester
Camera -LSTC105PL
Radio control servo
Servo plug in wires
Servo driver/tester
Servo aluminium clamp
Bike/ gear cable- used a rod originally works better with cable (easier)
2x rod connectors
Spring
2mm plate cut to shape (bracket for spring)
Obviously some small nuts and bolts
12v to 5v converter
Rubber seals
Wow :thanks:
robthebubble
LED & Headlight Master
Feb 22, 2011
1,442
Solihull, West Midlands
Camera -LSTC105PL
Radio control servo
Servo plug in wires
Servo driver/tester
2x rod connectors
Spring
12v to 5v converter
Rubber seals
I think a guide is needed here! lol
p11lkw
325
I do think pictures would really help to be honest. A picture can say a thousand words if you get me.
p11lkw
325
Looks like you will be pulling the boot to bits again to take some photos!
Looks like I might have to unless I use my old one and make another. I'll see what I can do by the end of the week.
Gonna have a go at some drls next. Have you changed yours ?
p11lkw
325
How is the camera you used, looks decent value and how is the night vision
I think this is the one
http://www.autobulbsdirect.co.uk/17mm-Universal-Reversing-Camera-with-Night-Vision.html
That's too big it won't fit. The one you want is from HIDS4U, camera size 17mm x 22mm.
The part number is LSTC105PL
I've not connected it to my HU yet as I'm waiting for the interface so I'm not sure what the picture will be like. Seen some pictures of daytime use and looks good. Don't think it's really a night vision camera but has visibility upto 5m
p11lkw
325
There listing different sizes so I couldn't say if it would fit.
Rns 510 interface
wjohnson
211
That is just immense! But how did you get it so it doesnt actually open the boot everytime you go into reverse?
robthebubble
Feb 22, 2011
1,442
Not changed mine yet as they are still fine. Will have a go at an adaption once I've doen my projector headlights and indicator/puddle mirrors!
p11lkw
325
Hope these help a little
epts2008
rule the bends
Mar 19, 2009
280
Chelmsford, Essex
This looks completely awesome!! Sorry to be a pain but on your parts list could you add where you got all the bits from really interested in doing this mod!
p11lkw
325
Most parts are available on eBay the camera is from hids4u. The servo and some of the wiring also the rod eyes you can go to a model/radio control shop but also on eBay. Some bits I got from work like wires, rubber seals/grommets and small nuts n bolts.
Once you've drilled your holes and fitted everything you need the seals for the wires etc so water doesn't come in.
