Stormflex
Picked up new Leon Copa Ecomotive last Wednesday. A few quirks with the media system:
1. Manual says that when the unit is switched on, the system starts, and the last selected audio source is played at the last selected volume. If I've had the radio on, next time I get in the car the unit itself comes on but I need to select 'Radio' to actually get any sound.
2. Is the only way to turn the radio off to turn the volume down to zero? Assuming you don't want to switch the whole unit off - could be using satnav for example.
3. Radio dims for parking sensors or mutes when a call comes in. But, it doesn't seem to do the same for the satnav. The radio and satnav just talk over each other so you can't hear the instruction. Is the only way to combat this to set the satnav instruction volume very high? Or can you set the radio volume to dim somewhere?
4. Driving home tonight and DAB suddenly cut out, closely followed by my phone disconnecting itself. An antenna icon with a line throughnit came up in the top left corner. Got home and turned ignition off and on but didn't resolve. Went inside had dinner and when I went back out an hour later it was working again.
Interested in anyone's comments or experiences with any of the above.
Cheers very much.
Cheers very much.
