Seat Leon Mk1 HID install
Haze
344
I have the LED H7's fitted to my Leon and they are mega bright. So much so, that I actually took my car to the local MOT tester to get my beams checked. He said they were the brightest he had ever seen but as long they were aligned correctly they should not blind anyone. Anyone mine were spot on for alignment. I will get some pics of the LEDs fitted to mine soon. In case anyone is interested mine were only £17 the pair off Ebay
Interesting, please link us! Was it a simple plug and play?
Sparkie
Angling Adict.
Sep 25, 2009
2,541
779
Middlesex
Is that plug on and play or did you change stuff? Sorry I'm clueless with power I'm a carpenter and stay away from sparks normally.
Sent from me!
bruceR
2,568
660
Monifieth, Dundee
If you are not rushed for time then you can remove the headlights and install them without having to drill the rear covers - I done this with a spare set of headlights.
I've done a write up in my Readers Ride ;)
Sparkie
Angling Adict.
Sep 25, 2009
2,541
779
Middlesex
Cool. I'll take a look.
Sent from me!
craigw131
yeah they are simple plug and play, just search H7 110W 22000LM LED on Ebay. It won't let me post a link cos I haven't made enough posts yet
These are the ones I have fitted. No need to drill holes in the covers as with HID's. Extremely bright lights and for the price you can't really go wrong.
Battoussai
489
150
Portugal
Hello everyone.
Like promissed I took some photos (not wedding quality but cannot afford a Iphone camera super dazzling to shoot at night) and hope you can get the point around this kind of tech.
http://s1064.photobucket.com/user/Batussai/library/
You can also see how it fits all into the headlight and all the easy DIY job and connections.
Suppose some equal light pattern can be meet between LED and Halogen light on the wall's photos.
Any question feel free to ask.
Regards.
verbal_kint
639
31
North West Kent
Thanks for putting those pics up, finally got to see them once photobox forced me to disable my ad-blockers and then had to get past all their ads.
I've ordered a set.
Haze
344
Yeah cheers for the pictures mate , hopefully the 9K lumen ones I've bo Got will be bright enough. They have 6.5K temperature.
Sparkie
Angling Adict.
Sep 25, 2009
2,541
779
Middlesex
I've ordered some LED s for the front lights. Does anyone know which bulbs to look for to change the front fog lights on the LCR over to LED as well?
Sent from my iPad using Tapatalk Pro
icestorm81
506
115
Dorset, Dorchester
I thought the max wattage you could use on standard wires and headlight in these cars were 55w?
Battoussai
489
150
Portugal
Yes, inside the silver bit is a fan.
Damn it! Forget to tell you guys to watch out those kits with fans!! Avoid them. It generates plenty of heat that fans dissipates into the headlight rising its inside temperature. Not good for all the wires and plastic cover - especially in the summer.
The worst is that those fans usually die soon and without vent the leds will burst. Another thing that some people refer to: noise. The fans make a Zummm noise after some time of use. And drains more energy.
I hope these facts won't appear right away.
Go for fanless kits. They use the method like computer graphic cards with passive coolers - no fans, just aluminium core and designed vents to dissipate the heat throught the metal. Some even use 4 or 5 metal sleeves instead of a bolk cooler.
Mine never got hot besides 20ºC.
Haze
344
Bit late for that now, these do have fans. I don't recall seeing any in the UK that didn't. I have a hole in my
Headlight case from where I had HID's, perhaps that will aid in ventilation. I also haven't seen an increase
In voltage. I'll see how we go, if i notice the fans have stopped working I'll think about my next step.
Anyway, LED headlights. I think they're fantastic. I had HID's as I normally do with my cars, but I found the output to be really crappy. I've had problems with ballasts and flickering. I found these to be nice and
Bright, the beam pattern appears to be exactly the same as halogen just brighter and further. They are 6.5K temperature so give that pure white with a tint of blue which regardless of what people say i actually like. These were actually easier to fit that standard halogen bulbs because you put the plate that sits under the silver prong in first, then slide the LED through and it twists and locks. If your thinking of going HID I would say don't bother just get some LED's. It's a great compromise.
Sparkie
Angling Adict.
Sep 25, 2009
2,541
779
Middlesex
Just bought some of these.
Didn't know about the fan thing so I'll give them a go and see.
Will let you know what they're like tomorrow.
Sent from my iPhone using Tapatalk Pro
