Got little on the car done this weekend
First i thought it was the Vband that leaked exhaust betven turbo and downpipe.
but we found out that it was exhaust manifold and again the gasket betven WG and manifold.
so we took everything apart did our own gasket from a asbest plate. old school but works very good my friend said..
Then we fixed the leak betven engine and E.manifold. And also rewelded the WG Downpipe that came in the kit. as it must be because of the construction of it the gaskets get blown all the time. Now with a flexi part welded on it. Will leave it to coater soon also.
And now with the modification on it i it doesnt need to be forced in place. So it should be same stress when cold hot cold etc.. And hopefully it will be good now.
And also changed the ABS module to one from a S3
heres before Coding and basic settings.
will go to my friend to try and get the remaining 2-3 Faultcodes away with a Real VW VAS computer.
And getting a bit nervous that the one i bought is broken or something??
but i was guaranteed it was fully working..
But it can be that i need to code and adapt with real VAS and we will try that later today.
the 2 ones i remeber that cant get away is
00493, ESP Sensor unit G419
01279, Longitudinal Accelaration Sensor
So still no ABS or ESP.
i hope not as it is a hell to change them and cost quite much money with 5liters of brake fluid to install it.. this time i put ATE Super Blue Racing brake fluid,
instead of motul RBF 600 i usually use, as it was out of stock.
but this is the same fluid as my friend that races with a Supercopa in 8hours races so should work for me if it works for them
And why not test new things
Also changed the oil adn filter so fresh oil again.
Castrol Edge racing 10w-60
Also tested so AWD still worked and it did
https://www.facebook.com/video/video.php?v=10150899940600168
We was supposed to do the Dyno and mapping this weekend after fixing the leaks and so.
But the Time ran away so we couldnt do that..
Hopefully soon. Quite annoying.
Car runs good but still want all the Horses to wake upp now!... xD
