Seat Exeo DRL or xenons
rehan2k7
Hi,
i just bought my first seat - exeo CR 143ps on extremely low milage (1940 miles) reg last year, its pre-facelift (i'm not sure what difference is there between pre and post face lift)
can anyone guide me on following questions please:
change my halogen bulb to xenon?
-if so what bulbs i need, i saw few guys here changed to osram night breaker H1 and H7 is that correct?
change the headlamp to DRL face lifted model?
or other solution?
i'm novice in changing bulbs and car electric etc.. also i want to make sure it doesnt void seat warranty.
many thanks guys.
damo74
176
Do a search for these online:
MTEC H7 12v 100w COSMOS BLUE HID CLASS UPGRADE BULBS
I just put them in my car, same as yours and they look like xenon bulbs. Very impressed so far. You will need to upgrade your sidelights - 2x per light as well as they will look too yellow!
rehan2k7
thanks mate, was this easy fit and any modification you had to do?
i believe H1 is for sidelights and H7 for dipped lights....can someone confirm that for me.
damo74
176
Definitely H7 for dipped lights, can't remember side lights to be honest but you can find out on Google. 10 mins to fit
junctiontwo
36
West Mids
I have some Osram H7 Nightbreaker Plus that are going begging as I've ordered Bi-xenons on my SE Tech due in May..... :)
stevea1234
53
I have the Osram bulbs fitted and they are a great improvement over the standard ones fitted to the car.
Although we all have different opinions, I would personally not go with anything that has a blue tint. The output is normally far less than a normal white bulb. Also, if the output is truly 100W they are most likely illegal.
rehan2k7
Thanks all - anyone know If I can purchase day time running headlamps and straight swap it?
M7R
Nerd...
Mar 27, 2008
327
Nottingjam
Don't put 100w bulbs in your headlamps!!!! You are ment to use 55w only!!! Any higher and you will damage the reflectors and the wiring, risking a fire! Plus it's not road legal!!
Use either osram night breaker plus, Philips xtreme or ring ultima max bulbs,
And no you won't be able to retrofit the facet lift factory xenons or the pre facelift ones for that matter with out a lot of work and cost!!!
rehan2k7
has any one used the following ones
Osram Cool Blue Hyper White 12v 55W
or
Philips Diamond Vision H7 12v 55w
or
OSRAM Cool Blue Intense H7
or
Philips Blue Vision Ultra
i believe H7 and H1 i need can some one confirm that for me as well please?
i'm planning to use cool blue intense for high beam and night breaker plus for low beam any thoughts
M7R
Nerd...
Mar 27, 2008
327
Nottingjam
Just use night breaker for both, the ones that are cool blue etc are either not emarked as they are too blue to legally emark, or if they are the light output will be lower than a bulb with no coating, or a coating just on the tip of the bulb, and generally when you have full beam on it because its dark and you need to see....
rehan2k7
thanks what fitment please H1,H2,H3 H4 etc?
