Scuttle Panel Removal
Keegs
I have what seems to be a common problem of the wipers on a Leon moving slowly, after a couple of searches it seems that it is the wiper mechanism, i have removed the wiper, but have have come a little suck at the removal of the scuttle panel, is this sealed to the windscreen? if so what is the best way to remove this and what is the best way to reseal it, and advice please.
Keegs
Thanks guys, for replying so quick will have a look at it tomorrow.
John
PAULTDI67
307
sheffield s.yorkshire
hi m8. thescuttle just pulls off .im having a simula prob with my mk1leon cupra .ive got a water leak in the drivers footwell it aint the windscreen thats been checed .poss the plastic wiring loomcover have taken this off this year &removed the foam gasket &re-sealed with instant gasket goo.not sure if its worked yet .tell ul8r
Deleted member 20376
ive got a slight whistle noise coming from my windowscreen, do you think this could be causing the problem of the scuttle not being fitted right?
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
No text speak on SeatCupra.net thank you!
PAULTDI67
307
:cartman:
Dont know wot u mean scuttle not fitting right.R u sure its pushed in firm? Thers a metal panel at base of windscreen with holes in it is it pushed firmly into the holes?Only whistlin noise i get is from the turbo at low speed then ucant hear it 4wind/road noise.
