ScottHmk4 - 1.2 Cupra replica (Now Sold)
matty_glanza
152
Cheshire
yeh had a look at jl audio website. its something called a crossover its just a little device that makes sure the right sort of sound goes to the right type of speaker.
so the high pitch sounds go to the tweeter
an the more bassy sound go to the speaker
matty_glanza
152
Cheshire
been looking for sum speakers for the rear, thinking maybe audi's bose speakers can sumtimes pick up sum bargains off ebay an they make a decent sound
Feb 28, 2008
3,990
Scotland
i dont think thts the same speakers i left in it. owell sound even better, thanks for the phoros too make sure you get a readers ride started once you get posting pics
Feb 28, 2008
3,990
Scotland
no mate i never did but i had an issue with the front anti roll bar, it was worn at where the bushes fit and caused knocking as it moved as it wasnt tight, i was going to replace it but never did, couldnt tell you what size bushes it will need.
matty_glanza
152
Cheshire
yeh its knocking now but I slid underrneath the best I could an tried to measure it an it seemed like it was either a 20mm or 22mm but that's will mean its probly uprated an it looks big for the engine size or I've just cocked up measuring it.
Blanco92
www.racedriversinc.com
Apr 11, 2010
2,496
Bournemouth/Cheshire
New ARB bushes are only a couple of quid from the dealer...
But it sounds like it's having the same problem as mine did, with a new ARB being required. The collars (which hold the ARB bushes in place) corrode which then allows excessive sideways movement of the ARB, which then knocks on various parts of the car! New ARB was about £50 from the dealer when I replaced mine. Then you'll need 2 new bushes.
Feb 28, 2008
3,990
Scotland
thats exactly it if i remember rightly, i just didnt replace it as i knew i was going to sell it so just put on new bushes
matty_glanza
152
Cheshire
Mines mainly when cornering my arb moved over to the left and you can see where its hitting the subframe as its wearing it down :(. But on a plus not I've just Order a 20mm up rated arb from sum fk racing or summit with the two bushes for 54 pound :) and a pair of puma droplinks for a tenner ;) hopefully that will sort the job out!!
