Don't you agree that it would be worthwhile to get some of these things documented also to back up these plots?
if folks want to do rolling acceleratiopn tests that would add some good data yea.
Why? I don't own a Leon and have been there seen it done it and got the t-shirt in 2 Leon Cupra MK2's![]()
Thought i had explained it in an earlier post but here goes again
I remember on some earlier Revo tunes they were requesting more fuel pressure than a standard pump could produce
as you have a upgrade you may be able to reach the values that are being requested
Its from memory so like i said im not sure if its 100% right so that's why I asked the question
Just for the record its not that the pumps could not produce the pressure , the pump could not sustain the pressure.
The pressure was constantly being bled off and rising back up again.
so a standard pump wont be able to sustain a requested 130 bar?
what I am trying to say is that is if it had a standard Fuel pump on would you have different results ?
Yes , if you run a car on Revos old 130 bar requested fuel pressure it will hit 130 bar but drop soon after , then would slowly build the pressure back up reach 130 bar again and then drop again.
People started to add the RS4 valve to overcome the problem , the only real way to sustain the the pressure was to swap out the internals for auto tech , kmd or apr pumps
The Tfsi engines were not the only one to suffer from that problem focus st also had issues holding pressure.
now this is why I don't think you could really call the badger wagon a stage 2 car
bare minimum spec is a HPFP and downpipe. It really should be changed for the UK though because some of the most popular downpipes are barely better than stock and seem more popular in the UK than most other places.
whats your advised spec list keith for your stage 2+ You mention minimum, but what mods do APR advise complement the code?
supporting mods? In order to make the most power? Well obviously just every well made part you want to throw at it. For me, and what most of our clients usually have, is HPFP, good intake, full 3 inch exhaust that either drones like crazy (means good flow too) or is RSC.
you can add all the other bits of course, discharge pipes, throttle body pipes, turbo exit to intercooler pipe, etc. WMI, dv upgrades, actuator, etc.
ok keith.. Given my car runs APR FMIC, APR HPFP, APR Downpipe/Cat, Miltek catback, Revo/Badger5 intake, water meth,CTS charge outlet pipe... Its power results from its relatively lower boost (relative to the day) is a comparison.
Your car is an outlier Bill. I do not know why. And yes, you had more mods than any other car there. You have a good down pipe and FMIC, better than most. WMI, actuator, discharge pipe, etc. To find out what software makes more power, you need to flash your car with something else and do a comparison that way.
What I am getting at is the old revo code tried to get the fuel pump to do something that it can't do properly
The addition of the pump makes that possible
I have always thought the addition of the pump makes it a "+" car I have ok have known people to have a stage 1+ tune, thus will take advantage of the replacement fuel pump
Looking at some of the logs its surprising to see the difference in intake temperatures. Some had wmi and some have better intercoolers etc.
From experience what you consider an acceptable intake temp on your RR such that it can be said the intercooler is adequate.
Also what sort of max intake temps do you see with the Welly Cooler.
