Whats a real shame is that you cant use the display in the dash, the one the radio info comes on to.
why that looks horrid!
hi xd, but isn't the -10.3 is going to be different each fill up, surely ??. It depends at what level you fill up at ?. I always fill up very close to the 1/4 mark give or take a tiny bit, but each time this figure varies depending on how much fuel it takes to fill up to the brim (+/- a gallon or so). If i was to set it to -10.3 every time then this would not be a true reflection of the exact amount of fuel i have put in (as shown on the petrol pump). Or am i completely wrong about that?
Best Regards,
Andy
i agree ! - however, check out the videos, it might look decent in the air vent, if you could do a proper job of installing it ! - i couldn't !!
Andy
I think you are wrong. It is not really used to get scangauge to give the exact amount of fuel put in. I use to get the overall scangauge mpg data to be accurate. The exact fuel amount does fall in line mostly though
When i fullup i basically fill up the car. Doesnt matter what point the tank is at before the fillup. Thats irrelevent.
The -10.3 comes from the over all calulation based on many fillups as is used to adjust the difference in scangauge reported mpg versus actual mpg.
at this stage the scangauge mpg is almost bang on exact as with actual hand calulation from the odometer and fuel used.
The figure did vary over time from 9.0 to 9.1 and has been steady exact at 10.3 for the last five fillups.
By the way, say you go in and it is set to 10.1 but you need 10.3 and when you click + or - it goes something like 9.8 for example. you just leave it at 10.1 press Done. Then go back again through fillup process and then can adjust it in .1 increments.
Over 15 fillups i have an actual mpg of 27.239 with the scangauge adjusted mpg reporting 27.246
I have that excel spreadsheet in my phone that update at each fillup before resetting the scangauge and driving off. can take a while though
