ok i found my answer on an american webby.... mikey u should find that u boost guage will say like 23psi or what ever ur thing boosts to now its tuned to fcuk... the MAP on the scan guage should read 14psi more.
the reason is the map measures Absolute PSI and the guage will measure atmpspheric PSI
"Good question. It is a different type of measurement.
the MAP sensors reads what is called "absolute" pressure, while a boost guage reads (normally) what is called "gauge" pressure. The difference is that absolute is referenced to a perfect vaccuum, while guage is referenced to atmospheric pressure.
so, normal atmospheric pressure at sea level is about 14.7 lbs/sq in, which is what the MAP sensor reads. A Boost gauge is pressure above atmospheric so 14 lbs MAP pressure = 0 lbs of "boost".
MAP-14 is an "approximation" of boost. since MAP pressure varies with altitude temperature etc. If you read MAP pressure with the engine off, or idling that is the number you should subtract to get boost.
hope this helps"
thats what i just stole from a webby lol
hope this does
help and mikey please confirm it for me
Smee
