Hi there !! - had my scangauge quite a while now and wondered if there were any new codes out ???. Would like to know if the g-force gauge can work on the Leon ???
Looking at the cleanmpg forum there looks to be a wealth of new codes on there, but unclear if they also work on the Leon ??
Here, to list but a few:
GAUGE: Solicited Traction SOC
CONF?: Yes, confirmed
UNITS: Percentage of Full charge
->TXD: 07 E3 21 CE
->RXF: 05 61 86 CE 00 00
->RXD: 30 08
->MTH: 00 0A 00 02 00 00
->NAM: Sts
NOTES: Solicited / Active gauge, so first char upercase
GAUGE: Passive Traction SOC
CONF?: Yes, confirmed on SG FW version "3.15" only not "3.15*"
->TXD: 03 C3
->RXF: 01 03 82 CB 00 00
->RXD: 20 10
->NAM: pts
NOTES: Passive gauge, so first char lowercase
GAUGE: Solicited L5 SOC
->TXD: 07 E3 21 CE
->RXF: 05 61 86 CE 09 00
->RXD: 30 08
->NAM: Sls
NOTES: Solicited / Active gauge, so first char upercase. RXF is looking for '00' in byte nine. For the traction battery this is the LSB for the battery current which would always (99.61%) read non-zero.
GAUGE: Passive L5 SOC
->TXD: 03 C3
->RXF: 01 03 82 CB 08 00
->RXD: 20 10
->NAM: pls
NOTES: Passive gauge, so first char lowercase. RXF is looking for '00' in byte eight. For the traction battery this is the temperature reading of the battery. It will only read 0 celcius, when it really is 0 celcius in the battery conpartment. GAUGES
GENERAL
GAUGE: BOOST (TURBO)
CONF?: YES - 2001 Jetta TDI
UNITS: PSI
->TXD: 68 6A F1 01 0B
->RXF: 04 41 85 0B 00 00
->RXD: 28 08
->MTH: 00 91 00 64 FF 71
->NAM: BST
NOTES: THIS WORKS FOR TDIs, NOT SURE ABOUT GAS TURBOS, IT USES MAP. REPLACE FF 71 (14.3 PSI) WITH 2'S COMPLIMENT OF LOCAL ATMOSPHERIC PRESSURE IN PSI (YOU CAN ADJUST THE NUMBER SO BOOST IS 0 AT IDLE). MATH IS #*145/100-143 (CONVERTS KPa -> PSI), SUBTRACTS ATM PRESS IN PSI
GAUGE: HORSEPOWER (GAS)
CONF?: YES-INSIGHT, ...
UNITS: HORSEPOWER
->TXD: 00
->RXF: 40 00 80 00 00 00
->RXD: 00 00
->MTH: 00 0A 00 17 00 00
->NAM: HPW
NOTES: THIS IS FOR GASOLINE VEHICLES ONLY, MATH IS #*10/23
GAUGE: INSTANTANEOUS MPG
CONF?:
UNITS: MPGus (OR LPK OR MPGuk DEPENDING ON SETTINGS)
->TXD: 00
->RXF: 80 00 00 00 00 00
->RXD: 00 00
->MTH: 00 01 00 01 00 00
->NAM: iFE
NOTES: OTHER TRIP GAUGES ARE SIMILAR, MODIFY TXD ACCORDING TO SG MANUAL
GAUGE: Manifold Air Flow
UNITS: g/s (0 TO 655.36)
CONF?:
->TXD: 68 6A F1 01 10
->RXF: 04 41 45 10 00 00
->RXD: 28 10
->NAM: MAF
NOTES:
FOR THE FEH...
(See vehicle specific link for more)
Corrections to LL Gauge coding:
GAUGE: Cylinder Head Temp
UNITS: Degrees F
->TXD: 07 E0 22 16 24
->RXF: 04 62 05 16 06 24
->RXD: 30 10
->MTH: 00 02 00 01 00 00
->NAM: CHT
NOTES:
MPH TO 1 DECIMAL PLACE !
mph xx.xx
TXD: 00 BC
RXF: 01 00 42 B4 00 00
RXD: 38 10
MTH: 08 D8 0E 93 00 00
NAM: mph xx.xx
Left / Right GForce
TXD: 00 2A
RXF: 01 00 02 22 00 00
RXD: 10 10
MTH: 00 01 00 01 FE 00
NAM: LRg
Front / Back GForce
TXD: 00 2B
RXF: 01 00 02 23 00 00
RXD: 10 10
NAM: FBg
Alignment (stear left / right)
TXD: 00 2D
RXF: 01 00 02 25 00 00
RXD: 10 10
NAM: Slr
Break Pedal Position
TXD: 00 38
RXF: 01 00 02 30 00 00
RXD: 30 08
MTH: 00 64 00 80 00 00
NAM: BPs %
Left / Right GForce
TXD: 00 2A
RXD: 10 10
NAM: LRg
Front / Back GForce
TXD: 00 2B
RXD: 10 10
NAM: FBg
TXD: 00 2D
RXD: 10 10
NAM: Slr
TXD: 00 38
RXD: 30 08
NAM: BPs %
Battery AMPs (passive)
TXD: 00 33
RXF: 01 00 82 3B 00 00
RXD: 14 0C
NAM: bta
GForce to Right x.xx
TXD: 00 2A
RXF: 01 00 42 22 00 00
RXD: 10 10
NAM: gfr
GForce to Back x.xx
TXD: 00 2B
RXF: 01 00 42 23 00 00
RXD: 10 10
NAM: gfb
Stearing (degrees left) xx.xx%
TXD: 00 2D
RXF: 01 00 42 25 00 00
RXD: 14 0C
MTH: 00 64 01 BC 00 00
NAM: sdl
Break Pedal Position xx.x %
TXD: 00 38
RXF: 01 00 22 30 00 00
RXD: 30 08
NAM: bps
TXD: 00 33
RXD: 14 0C
NAM: bta
GAUGE TXD RXF RXD MTH NAM Notes
State of Charge 07E321CE 056186CE0000 3008 000A00020000 SOC %
Battery Voltage 0033 0100023B0000 2010 000100010000 BTV HV Battery Volts
Battery Current 07E321CE 056186CE0000 3810 0001000AF333 BTA HV Battery Amps
GForce to Right 002A 010042220000 1010 00010001FE00 gfr x.xx G's scaling a guess
GForce to Back 002B 010042230000 1010 00010001FE00 gfb x.xx G's scaling a guess
Stearing 002D 010042250000 140C 006401BC0000 sdl Degrees left xx.xx %
Brake Pedal Position 0038 010082300000 3008 006400800000 bps xx.x % depression
Battery Current 0033 0100823B0000 140C 000100010000 bta Passive CAN request
Kilometers per Hour 00BC 010042B40000 3810 03E804000000 kph xx.xx kph
Miles per Hour 00BC 010042B40000 3810 08D80E930000 mph xx.xx mph
Gas Pedal Position 024C 010282440000 4008 000A00020000 gps xx.x % depression
State of Charge 03C3 010382CB0000 2010 000A00020000 soc Passive CAN request
Battery Temp (upper read) 03C3 0103023B0000 3808 000100010000 buc °C max for the 5 ms cycle
Battery Temp (lower read) 03C3 0103023B0000 3008 000100010000 blc °C min for the 5 ms cycle
Battery Voltage 03C5 010302CD0000 2010 000100010000 btv 3CD pid reading
Ignition degrees before TDC 052E 010502260000 1810 000100010000 ign Passive CAN request
EV Button Status 0521 010522290000 3101 000100010000 evb EV button ON or OFF
Engine Coolant Temp 0525 0105822C0000 1808 000A00020000 wtc xx.x °C
Gas Gauge 05AC 010582A40000 1808 006400040000 gas xx.x % full
Best Regards,
Andy
