Abit of advice for everyone. I struggled to get the screw out the white plastic bit. I cut the backs off the plastic bit, the parts that are in the boot, and lifted the black trim off as one. I then seperated all the parts and replaced with a normal screw. When I put it back on i flipped the white bit AND put it inside the boot and screwed the screw into it, so essentially like a nut and bolt.
It works alot better and the black plastic trim is held on more secure, the centre bit where the 'S' badge is is straight and tight. And the whole lot can be removed easily again.
good advice man! Will bare it in mind - as I still haven't managed or really bothered to try an get mine off as of yet :) thanks!
