running without remap...?
jasengine
2.0L TDI
Oct 29, 2007
213
Wiltshire
Does anyone know if it would be ok to run with the following parts, but not a remap, for..say 5 months?
.216 injector nozzles (P502's)
CR turbo's, Garrett hybrid GT1756
large FMIC and ally pipe work
PD150 inlet manifold
South Bend stage 3 425 lbs/f clutch & lightened flywheel
Larger oil cooler
3 bar MAP sensor
jasengine
2.0L TDI
Oct 29, 2007
213
Wiltshire
over fueling etc , why not get the map done sooner then ?? surely a tuner could sort a deal it if they are to fit it/ supply
unless ur fitting all yourself
I have the injectors installed already with slightly raised boost and the engine runs very well, but when I fit the larger turbo and custom pipe work myself, I'm not sure how it will run until I can get a remap. Custom code have said they can do over a few days. But funds to do it all at once are going to be a bit of an issue :(
MattFrench
No poke without smoke
Jan 16, 2007
112
www.rsfrench.com
As your changing the Map sensor and the turbo at the same time all should be ok. Your ecu would recieve a similar scale of reading of boost as with you old setup. However, I would not drive the car hard.
Hugo1.8vt
to place a larger turbo you need the MAP sensor leon PD150 and a radiator of diesel
will notice the radiator with less consumption of diesel
