running on 3 cylinders
kilobrown
Leon cupra R
Apr 17, 2007
114
west- lothian scotland
jumped into the leon today driving normaly went too give it a little bit of gas and boom started running lumpy as if it was running on 3 cylinders!!!
sounds very like a subaru engine, so am slightly worried any suggestions or anybody had this problem before???
its a 03 LCR :cry:
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
If it sound like a subaru! then it is the coil pack, but check you spark plugs also at the same time!
Pabs
5,936
Basingstoke
usually you'll see an Engine Management light flashing on the dash..... my first coil-pack failure was this time last week - not bad considering i've owned the car for nearly 3 years! :)
Pabs
5,936
Basingstoke
Depends which coilpack is gone - but even the hardest one only took me 8mins to do (i timed it) - and that was in the pouring rain!
The coilpack I got last week (revision R) - #06B 905 115 R - cost me £29.90 inc. VAT from the local VW garage.
EDIT: Hardest bit for anyone without VAG-COM would be to figure out which coilpack is faulty. Otherwise, it's disconnect cable, pull up carefully (don't wiggle) and replace.
Cylinder 4 is under a vac-reservoir and bracket which requires a 5mm allen-key to remove the 3 bolts, and a 13mm spanner to remove the reservoir.
