rough idle issue
flashbsd
Hi all, noticed that once the car is warm, the idleing is a bit jumpy, say 100rpm in the 900rpm range. is it me being paranoid?
when i 1st got it was smooth as anything. not had its service yet.. :redface:
also anybody work out why the electric windows have decided to stop 99% and needing an extra push of the button to seal them tightly?
thanks all :)
Stevo1
577
St Ives, Cambs
How long has it been without a service? Sounds minor, but its amazing how many rough idling problems are solved by an oil change, etc...
I would be interested in the window solution as well, ive tried the old hold for 10 second trick but to no avail :(
flashbsd
hi mate, i need to double check, but it could be 2004 sometime, not long had the car, and had its major 40k service already, 22k on the clock mind you ;)
flashbsd
yep sure is. i think im going t obook iti n for a inspection service, as its done 6k since jan 04, so doesnt need a major service. and get them to change brake fluid on top etc. ill get them to take a look when its in there :) cheers for ya help guys
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
cupra_matt said:
coolant temp sender. Temp sender is a common problem on the 1.8T
common old fault since VAG took over on anything remotely injected - wierd huh? maybe i should start a reliable temp sender company - all manufacturers seem to suffer the same fault
signs for that usually show as a change of running once off the *choke* stage
ie
runs fine when cold - crap when warmed up
or
crap when cold - great once warm
if it helps
flashbsd
cheers guys, starts 1st time every time! flap you got any prices on temp senders? or replacement dv incase so i can query price?
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
for a 20vt - from memory ;) is a blue 4 pin in the water hose housing
about £20 odd
flashbsd
cheers mate, booked it in for a inspection service, with 20k extra's to be done.
e.g. Pollen filter etc, mentioned the rough idle and hopefully they will sort it.
got courtest car too :) all be it a 1.2 mk4. get me to work ok ;)
he said 140 for service plus a brake fluid change, @ 44.95. which i want done as when my clutch master cylinder went, it lost some of the fluid :)
Terra78
Hi there Fla@pper, I've had a rough idle problem for over 6 months (Ibiza 97 2.0 GTI 16v Cupra) and noticed that it only runs crap when it has reached operating temp. Changed temp sensor, coolant sensor, throttle position sensor and a few Vacuum hoses but you reckon it's the temp sender?
