Status
Not open for further replies.
alexj124
294
Edinburgh
presumably this is mapped in to the ECU?? as you dont want to have to keep pressing a button everytime you hit full load?
or am i missing something here?
Jan 8, 2007
2,958
Wiltshire
Looking forward to seeing how much timing you can run with this kit :) Nice
Have you decided what ratio of water/meth you're going to run yet?
RobDon
Pro Detailer
The kit comes with a progressive controller which feeds the water/methanol in gradually based on the boost settings you put in, no mapping required unless you want to advance the timing, but you can do that yourself with Unisettings or Lemmiwinks.
http://www.alcohol-injection.com/water-injection-parts-3/progressive-controller-14.html
alexj124
294
Edinburgh
ah thats right i did read about the MAP/MAF sensors being used, my bad!
Good stuff though be interesting to see what extra timing you can put in. Think i saw something from bill that you can 'roughly' work out the extra BHP by the degrees of timing you can add
xnox202
1M ST-TLD
Apr 15, 2008
182
Brunei Darussalam
This is going to be promising. All the best RobDon! Make sure you take another engine-bay pic? I'm always admired by the works you've done!
Umm..
Now is this possible with N/A setups? :p
jamiebennett81
Good for any turbo car I reckon, keeps the intake temps down and allows you to increase boost and timing safely.
hmmmm...k03hybrid will be running max 25psi I reckon...which is more than CR turbos reckon it should be running
dont thought any more boost should be dialled in
jamiebennett81
I won't be adding any more boost myself, just enjoying much cooler intake temps and advancing the timing.
That's the thing with these tiny hybrid K03's - they are pushed hard to make power.
swings and roundabouts....they aint laggy either ;)
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
Does the advanced timing not bring extra boost with it whether you want it or not
Status
