There's an idea, you can load the stage 3 map onto my ecu on the bench. Can you supply the plug in module too (SPS3, select plus??) Cost?
Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
hi mate looks awesome im in two minds to go bt or stick with the hybrd, ive spent so much on engine so i should use it to its potential, what clutch you running, i had a read through thread but couldnt find it and internets slow where i am, what figures you hoping for? and is this a daily drive or a weekend toy?
Sounds good but really can't see how they can map it when your cars not with them surly that's a generic map there supplying you with I would want map set to my car on the rolling road and mapped on the road to get the best
One 'VAG' tuner used to run K04 maps on their Big turbo conversions with stickers over the MAF to confuddle the sensor reading.
They used a dyno too, and called it custom![]()
