rf's FR TDi - NOW SOLD - Another Car Change 2013!
vroomtshh
4,222
Dreghorn, Scotland
Its an m12 or m14 spline bit. Can't remember which off the top of my head.
Not something you could buy in halfords. If you were interested in doing it yourself (I kno ur not), I have the bits.
U must have spline bits. You've removed the front seats before?
rf860
3,575
scotland
Yeah, i've got a set of splines. I am right that the whole strut is removed? Hoping the suspension is going to be changed soon :D
mick-fr
Mégane F1 R26..
Dec 1, 2009
2,406
At a Shell garage..
Yeah you have to remove the whole front strut either to fit springs or coilovers - Bit of a pain in the Ibiza (especially drivers side due to the drive shaft) but it can be done.. I fitted my coilovers myself :) The rear you can get away with just removing the bottom bolt if only swapping springs, but for coilovers you obviously have to remove and swap the lot :)
rf860
3,575
scotland
Yeah thought that was the case. Hmm, next month i think i'll get the ride sorted for the horrible winter we are due.
mick-fr
Mégane F1 R26..
Dec 1, 2009
2,406
At a Shell garage..
With your big heated garage, you should do them yourself.
I've never had a problem with the drivers side although I know some folk do.
4 hours will breeze it
Heated garage? I'd definately do them myself :lol:
Yeah 4 hours is more than enough, the back can be done in an hour tops and that's if you're not sure what you're doing.
vroomtshh
4,222
Dreghorn, Scotland
Exactly. I did my first set outside on the road in December lol.
If I had Ross' garage, I'd probably never go in the house again :lol:
rf860
3,575
scotland
Lol, might try the back ones myself first to see how i cope. Garage is currently full of old furniture etc. wish my parents would stop decorating! What tools are needed? I should actually get some axel stands rather than the jack made of playdoh!
vroomtshh
4,222
Dreghorn, Scotland
If you can change a wheel, you can do the rears. Rear needs a 16mm socket and spanner.
2 bolts at the top of each shock to remove the mount from the car. 1 at the bottom. When it's off remove the mount from the shock (sure its 16mm too, mab 17) swap the top mount and rubber boot over and refit.
Springs just pull out when both shocks are removed
I don't use axle stands when doing the rears, because if you put them on the beam, you can't get the springs out and there's nowhere else decent to place them
rf860
3,575
scotland
Cheers, what do you use then?
J20ROBO
303
Ayrshire
Bottom front hub bolt is a M12 spline> if you cant get a hold of one you can use a good set of vice grips around the bolt... A have fitted 2sets now its pretty straight forward bud
rf860
3,575
scotland
Cheers robo, looking at suspension all afternoon, safe to say i'm totally baffled! So much conflicting info on the net....
Blanco92
www.racedriversinc.com
Apr 11, 2010
2,496
Bournemouth/Cheshire
Saw someone mention about not being able to get the spline tools etc from Halfords... well you can :)
Bagged myself a set from M6 through to M16 from Halfords at the weekend for £22.99.
Unfortunately I didn't buy it to fit coilovers :lol:
rf860
3,575
scotland
New dual mass flywheel, clutch kit, slave cylinder and rear engine mount fitted this week while i had the joy of a fiat punto. Thank christ it was all under warranty apart from the dmf which i only paid 30% of. Not impressed to say the least. At least it feels brilliant to drive again and the gears feel like new :)
Only things i've done recently is cupra handbrake cover, vent clips (thanks mick-fr) and pd160 air intake (thanks mick-fr). Getting my wheels done soon in dark grey and possibly getting coilovers.
