I belive I'm running same setting as you, and I only ever run it on shell vpower! I have a forge 007p, large cone filter, forge unos MBC, n249 bypass feels grate or it did till iv had a massive head ache with HEA gadkets!
Yes, CF = correction factor. Basically how much the car is pulling back timing by to reduce knock.
Does look a touch on the rich side but then Revo maps usually do apparently, my recent logs are about the same. I asked the tuner that mapped mine about it, he reckoned that's pretty normal. Part of the reason is to keep cylinder temps down as this means lower exhaust gas temps which in turn allows you to run more boost using the SPS gadget. I assume this is also to ensure there's sufficient fuel to cope with more boost since you can't adjust fuelling on 1.8T's.
so, completed 2 runs yesterday on the moon.
[1] 0.77
[2] 0.78
similar figures to yours Chris.
[1] 0.77
[2] 0.78
