Sounding that way John.
Any power on the connector when ignition on?
Right, update to this.. found what i thought/hoped the problem was. Broken wire from loom to connector.. cut other wire, soldered some new wire in taped all up, lovely jubbly i thought.. got approx 9 1/2 volts or so across the connector with electrics on so was at least getting something. So connected up .. checked rear lights.. nothing!
seems possibly the switch is goosed as i also checked for any voltage at the clusters , nothing
tried to remove switch.. would it budge? would it 'eck as like, so give it a quick squirt of easing juice and made a coffee. set to it with a pair of pliars and it turns and turns
and turns
and turns..
does the switch come out of the big nut its sat on/attatched to or do you have to remove the nut too?
