Reverse lights question
A5HL3Y
82
Newport South Wales
Does the gti have a fuse for the reverse lights and am i right in thinking it has 2 reverse lights as i noticed i havnt got any working but must have gone in the last week as i had MOT monday
cheers
A5HL3Y
captin_urbis
Not a Member
Dec 2, 2008
452
Lancashire
yeah there should be a fuse, check the lower glovebox under stearing collumn, should read all fuses and order. if not check the bulbs
yes there is 2 lights btw each running on one fuse
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
Easy to put a new switch in.
To test the switch...
Right on top of the gearbox.... (There are two electrical connectors, the rearmost one is the speed sensor.)
To check, pull the connector off, ignition on, see if there is 12v across the connector (there should be)
Secondly, out of gear, then see if there is infinite resistance across the switch terminals. Then, stick it in reverse, there should be minimal resistance. If there is still infinite resistance, the switch is goosed.
robreidmotors
RobReid
May 10, 2008
677
Lancashire
sorry i went all gangster for a moment lol
Yeah and gangstas dont have em cos their rudeboy innit, west side
Serious thing, i just did mine and i dont know if a previous owner changed the connector that goes onto the switch, but i ended up having to use a knife to cut off the two little plastic 'moulds' as they stopped them going into the connector.
Just in case anyone else has the issue.
A5HL3Y
82
Newport South Wales
the bulbs look fine to me, so i will check the fuse tomorrow and put 2 new bulbs in incase and if its still not working then a new switch will be required
caddyrage
Nurburgringer!
Jun 26, 2008
95
Ellington, cambs
My van is doing the same.
When you put it in reverse, you can see the lights flash on then go off straight away.
Common problem with the gearbox switch. Your best to take the switch out to write down the part number as there's a few out there and not all work.
robreidmotors
RobReid
May 10, 2008
677
Lancashire
I got mine from GSF, think it was only about five pounds, works fine, seems well built etc
Brummy
Nazi Moderator-Bot
Mar 6, 2005
4,275
Moved to the DarkSide
Checked mine as the reverse lights have never worked since i got the car.. following what it says in the Haynes liarbook, im getting (with no electrics at all) naff on the switch in any forward gears, but the multi-meter beeps continuity when reverse is selected .. figure the switch is ok?.. bulbs are all ok..holders are fine ( have tried other complete bulb holder units and same issue). Damn! kinda tells me the issue is somewhere in the wiring ?!?!?!
Brummy
Nazi Moderator-Bot
Mar 6, 2005
4,275
dunno Dave, i was just out getting something out of my van and grabbed the multi while i was out there..will give that a try next, at least theat should tell me which side of the loom its likely to be.. be a decent idea to check for any voltage down at the rear end too, altho' as i said, ive swapped bulbs and the clusters, so :shrug:
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
mine flash now and then but it's the huge black plastic housing type which i can't be arsed to buy and fit :)
Brummy
Nazi Moderator-Bot
Mar 6, 2005
4,275
the clusters themselves? ive got a spare (pair) lurking around in my cubby under the stairs fella..i can get them down to pod for you if you want them ? (if your not going , surely someone local to you is?
