reverse light not working
craig87
beeza lover!
Mar 14, 2007
439
Where do i start??
Ive checked the bulbs and they seem fine tbh.
I dont really know where else to look its a 2.0 8v gti cuprasport
stinkypete
174
Chesterfield
erm, Haynes manual showed me! It was a while back when I did mine - if I remember rightly, it's really easy to get at - gearbox is on the right of the engine as you look at it - the switch is located slightly towards the rear of it & you'll notice it has a wire coming from it. Like I said, it just unscrews (with a spanner) - if you have a nosey, you'll spot it. Failing that though, have a look in the Haynes manual (libraries have 'em if you've not got one). Unless someone on here can explain it better than me?
craig87
beeza lover!
Mar 14, 2007
439
I was guna buy one the other day and this has made me decide to buy one!!
They help so much, id say your probably right mate thanks for the help!
craig87
beeza lover!
Mar 14, 2007
439
i dont know if its in same place mate but mine was simpleto find its right next to my computer cable on the transmission. Two core cable with two pins, use cable to loop the two together, hey presto reverse lights on switch broken!!
£9 from seat woohhhooo!!
Feb 8, 2007
108
Aberdeen, Scotland
just out of interest. did ur reverse lights just completely stop working? i ask because i put a new gearbox on, they didn't work when i left the house! a few hours later they worked again. then they stopped!!
craig87
beeza lover!
Mar 14, 2007
439
i dont know mate i bought it like that, the guy didnt tell me the reverse lights werent working i found out when my mate was following me back from where i bought it when i reversed out of a parking bay!!!
craig87
beeza lover!
Mar 14, 2007
439
if you do what i said and bypass the switch witht he wire looped in to it and your reverse light becomes constantly on then its the switch mate, it could be faulty and work sometimes. Like i said £9 to replace and a five min job
davenlucy
before you delve into the engine bay you may want to have a butchers at the bulb holder for the reverse light coz if its crudded up it wont get a contact and make the bulb not work.
craig87
beeza lover!
Mar 14, 2007
439
i doubt its the bulb, you would be unlucky for both sides to go at the same time!!. Honestly it took me 1 minute to find the lead in the engine and test it how i have said above. Check bulbs if you like up to you but if both sides have gone then id check electrical system!!!!!!
