Resonator delete
Cupra101
29
9
Hey! Question.... the resonator delete pipe for the Cupra 300. Can this be done as a straight swap without effecting the car in terms of, do I need to map the car with the res delete pipe fitted, will the pipe cause issues with fueling or performance if not mapped?
Not settling for a turbo back system or mapping at the moment and would like something a bit more from the Zorst note and these delete pipes sound great.
Advice welcome...
Tully1980
267
135
Advice welcome...
Hi, I’ve recently had the res delete done on my Cupra 300. It’s a straight swap (original exhaust needs to be cut once, and resonator delete pipe is then clamped both ends). No effect on fuel economy or performance, and it doesn’t need to be remapped. Hope this helps
Tully1980
267
135
Oh, and it sounds frickin’ awesome
It’s hardly any louder when you’re driving normally, but give the throttle a little tickle and people will hear you coming
cupra300uk
288
106
Here we go again! Just out of curiosity you said that yours was a lease wasn’t it? Is that where you have to hand it back at the end or is it similar to my PCP? Anyway I was wondering because I was unsure whether or not you are allowed to add modifications to a car that isn’t technically yours? Struggling to get hold of my dealer so need some answers to this as it’s the only thing stopping me from getting the resonator delete!
Daire92
Cupra 290 DSG
Jan 6, 2016
288
200
Ireland
www.instagram.com
The basic rule of thumb for all this kind of stuff is that by the letter of the law, you should not be making modifications to a car you do not 100% own. The leasing company is well within its rights to charge you for this stuff when you hand it back. With PCP its the same if you plan in handing the car back at the end of the agreement, if you plan on buying it out it will only really affect your resale. They are not going to be coming around checking your car so its usually fine to do mods here and there. Your main concern will be warranty and insurance, you will be voiding the warranty of any modified parts and possibly, parts affected by it (i.e resonator will void entire exhaust warranty, lowering springs may void shocks, suspension bushings and bearings). Undeclared mods will void your insurance in the case of an accident leaving you extremely vulnerable to massive costs. Mod at your own risks essentially.
Tully1980
267
135
What he said
Reactions: cupra300uk
Lmbarrett83
1,538
619
Sheffield
Forgive my ignorance but would this still be possible/have the same effect on the M19 CUPRA?
Not sure what the exhaust changes means for things like this.
Sent from my Pixel XL using Tapatalk
AndrewJB
Aug 16, 2007
11,175
485
Maranello
Absolutely pointless asking a SEAT dealer if you can modify a car. they will say No even if you own it 100% outright.
Cupra101
29
9
Cheers buddy! I just want to make sure this wont effect, fuel economy or any of the performance without a map! Pretty much OCD like that. Yeah, i have seen videos and it sounds great!
R4CK5
609
85
Mine said I could on my pcp which was good. If the bits modified were not seat parts I'd either have to go back to stock or pay a sum for them to apparently. This only comes into effect when you simply hand it back, if you trade it in you can send it back however you want to.
Sent from my SM-G950F using Tapatalk
cupra300uk
288
106
He was the one who recommended that I get the resonator delete in the first place as he has had it done on his cupra lol
Copra68
549
306
Even on a lease if you wanted the resonator delete as long as you put it back to standard for it getting picked up at the end of lease nobody would have a clue. It goes straight to an auction anyway.
cupra300uk
288
106
So as long as nothing goes wrong and don’t need to the warranty to be covered it should be okay come the end of the agreement? As if I wanted to keep it then it’s no problem at all but if I wanted to give it back I’m able to reverse it?
Copra68
549
306
Yeah it won't cause any problems at all. Take it to an exhaust shop with a good reputation near you (ask on here) tell them you want it so that it's reversible and you can get it changed back over. Keep the old bit of exhaust for when you need it and it'll get welded or bolted back on.
cupra300uk
288
106
Cheers for that will look into it
Jib
496
31
Doncaster, South Yorks
I also had this done on my 300 2 months ago. I am interested to see how you get on with yours as mine has become increasingly louder to the point where its pretty unbearable and i am contemplating putting the res back on. The motorway drone is getting louder and the pops and bangs are ridiculous. I have had the pipe checked and its fine with no leaks. I have a hunch that the baffles in the rear box are getting destroyed
Titchy
519
208
Buckinghamshire
That’s interesting to know if indeed the baffles are being destroyed then if you put the res back on it may sound louder then original?
plugNNN
26
Looking to get this done on my 280 cupra as well! Any recommended places in Hertfordshire?
