Replacing antenna
Jan 19, 2022
Hi. I am thinking of replacing my antenna on my Leon 2012 because everytime I drive my radio keeps losing signal, it only works when I'm stood still but as soon as it start driving it loses signal, I've tried tightening the antenna but it seems a little bent and worn out so I'm going to try replacing it.. my radio has DAB stations, I was wondering if I can just put any antenna on it or are there specific antennas I need to make sure the DAB also works
380bhpdaily
1,261
574
If your headunit is a aftermarket one you’ll need a DAB Ariel which will stick to the windscreen you can buy it from Halfords. That’s why yours is so bad as it doesn’t have anything by the sounds of it. The old factory one won’t work. Just go to Halfords and have them fit one for you.
