Removing the Horn
Nath.
The Gentlemans Express
Jan 1, 2006
8,619
16
EASTLEIGH, HAMPSHIRE
Nathwarr.... is the alhambra horns easy to fit (do they sit straight into the old holes) or does it require work?
easy as in 1 plug and 1 bolt yes, although it is very tight in there and the mounting brackets for the horns will need bending
buy yourself some plasters for your skinned knuckles
jnc90
100
i fitted mine by taking the grill bit out around the fog light and then taking a couple of screw out that hold the bottom tray bit of the bumper on so i could get my hand underneath
How did you get the grill out Aimez?
Also, hwo much wiring is onvolved to just replace the standard one? :)
