Horn issue
Mar 24, 2025
48
15
I would be startin ther mines been acting up as i had her parked over winter used her a few times seems to of fixed its self it was my indicators
U can get cheaper ones all the electrics for all the steering wheel buttons run threw that first b4 the button ovbs
Fipsy
90
7
Tamworth
Cheers, already replaced the clock spring with a brand new one, and the fuse and relay too. Made no difference. But I’m booked into an auto electrician next week so fingers crossed they sort it.
Fipsy
90
7
Tamworth
Then 2 the bcm wich is body control module
Is that the part under the clock spring when it’s in situ? I did have a look at that but couldn’t see how to remove it. Admittedly it was getting dark when I looked at that. They a cheap replacement?
Mar 24, 2025
48
15
As daft as it sounds check the wires behind and under the battery tray they rub on the tray then split mine had four broke wires thers wen i bought her repaired them fixed around 8 fault codes mainly abs/ac plus a few others car ran fine just had intermittent faults turned out to be the wires
Mar 24, 2025
48
15
I repaired and added foam pads at the rub points taped over them 👍
Mar 24, 2025
48
15
Think so mate never had one apart but i want to do an mk6 r steering wheel upgrade so u need the wheel clock spring and control module the the new module coded to ur car basically copy ur module settings to the new one so i know they allwork together threw some research
Fipsy
90
7
Tamworth
That’s a good shout. Hadn’t thought about that. I’ll go out and have a look now. Thanks for the heads up mate.
Aug 14, 2023
Hey OP any updates? I have the same issue, every fuse in the car is fine. We tested every relay and no problems.
New clock spring, when we give the horns 12v they work.
Last thing I can think is a wire got damaged while I was driving?
Fipsy
90
7
Tamworth
Not as yet mate. Booked in for 9am tomorrow at an auto electrician to hopefully find the cause. Mines the same, changed fuses, relay, clock spring and tested the horns with direct power (they’re loud on a bench) but nothing from the steering wheel. Will update tomorrow once I’ve been.
Aug 14, 2023
Please update. I got the code now 01426 - Controls in steering wheel. I wonder if the model died.
Also I see now my sunroof is abit suspect for leaks.
Look forward to hearing. I will also post my findings
Fipsy
90
7
Tamworth
Soooooo I’ve just got back from the auto electrician and am pleased to say it’s sorted. Turned out I didn’t need to replace the fuse, relay or clock spring as it turned out to be a break in a wire behind the relay. Obviously not something I could’ve spotted with my diagnostic tool as theirs was a propa in depth one. Basically where you remove the cover to access your OBD port the relays sit in there and it’s a wire that feeds to/from the relay that had a break in it. He bypassed that wire and all good. I’m now road legal again 🤣. MOT booked for the 15th so all good. Appreciate all the replies to this thread, you’re a top bunch 👍🏻
mty12345
4,084
667
bristol
glad you got it sorted mate
Reactions: Fipsy
