Removing N249 valve - How To Guide
Rogge
Perhaps a bit old thread, but here's a 'maybe' answer
I think all the DBW cars have this N112/N249 combo. Just to give te ECU the control over your boostpressure. I think it used when the car goes in ABS/TCS state, or when you hit the brake will keep on the gas (can't be done btw). When the ECU detects this state, he will cut back the power (DBW) en therefor the boostpressure must be cut back also.
Other explanations or comments are welcome ;)
Tony20VTurbo said:
Good point Glen, which is what myself and Damian were asking ourselves, along with Pete from Seatowners as well
if this N249 valve has been put there on later models, it must be there for a good reason......otherwise why put it there
surely removing this must have some sort of effect or it is obviosly there to control something for safety reasons, but what for exactly
i am all for removing it, and i have read on other forums (Vortex mainly) that no error codes etc have been produced from VAG com, but still i am a bit sceptical as to what harm/damage this can do to the car, manufacturers dont just put these things in to be removed, well to a point anyway
dont think i have seen anyone quote and answer Glenns or Petes queries, although not read the whole thread
so could anyone perhaps look into why VW have put this N249 valve onto the later models and what effects it has removing it, apart from improved performance but i mean engine reliability, hope nothing to worry about as i really want to do this though
cheers
Tony
Deleted member 9043
is it ok to put the vacuum from the check valve on the vacuum of the fuel pressure regulator?
so you have a straight vacuum fromm manifolt to dv?
ive done this mod to now and car feels way good
Nov 2, 2004
9,335
South Wales
Cool, is it still stalling then?
Any more thoughts on that MAF/tip thing i mentioned?
I'm tempted to do it to clean up the engine bay more as well as tryin to sort my stalling thing.
Dave, take a look at the first page of the thread for the 'how to' matey. Sim explains it very well. The only difference being I didnt ditch the unused parts (I left them there just not unconnected mechanically - Electrical connection to the N249 valve is still in place)
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
Got you. You didn't make/fit resistors. I'd read and understood Sim's guide ages ago, just wanted to see if you had done something different. Thank you! :cheers:
Shock_Xe
done this mod to my car and adams nearly a year ago, no probs what so ever
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
CupraT said:
Good pics Martyn.
Does anyone have any pics of the setup, when:
* The N249 and vaccum bath are moved completely
* When you're running a K03s etc
Thanks in advance.
claudefrog
683
At home
www.reallymeansounds.com
does that mean you never used the resistors? just left the n249 connected and removed the rerouted the vac lines?
